how to get more turning....??
#16
Too much spring tension, too much preload and too heavy oil could give you some adverse turning problems. Try as light a spring rate as possible and 25wt oil and try to maybe get your dogbones level in the rear. If you go to tighter suspension, it's good for straight-away jumping and loose-pack but anything hardpack or clay needs soft suspension to get a grip.
