Old 01-28-2009, 08:24 PM   #31
Joe Ford's Avatar
Send a message via AIM to Joe Ford
Don't cheap out on the batteries guys...we can't stress that enough. You've got this beautiful $350+ ride, a $250 system for it, and then to power it use so-so batteries. The system is only going to be as good as the batteries powering it. Also, ripple current causes more ESCs to fail than anything else. This phenomenon takes place when the ESC is switching on and off thousands of times per second. The batteries obviously cannot do that so the capacitors store a charge to get the ESC through this, and smooth the current and voltage out. If the batteries cannot provide enough voltage/current to keep the capacitors charged, the caps keep trying to dump but there's nothing in them...they get hot, and if they get hot enough the electrolytic fluid inside boils and the cap fails. When this happens your ESC is open to those huge current swings and it'll go up in smoke. We will not cover the ESC under warranty due to inadequate batteries. 4000mah 20C is the absolute minimum. The higher those #'s are the better. I personally don't use anything less than 5000mah 20C, or go up to 4500 30C. My .02
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 01-28-2009, 11:59 PM   #32
onefast8's Avatar
Trader Rating: 41 (100%+)
Thanks for the info Joe!
Makes a bit more sense now.
onefast8 is offline   Reply With Quote
W.E.D. Winning Edge Designs questions and comments... W.E.D.Jim Painting, Designs, Graphics and Photography 3693 Today 07:12 AM
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Ok I give in. 1/8 brushless qustion's. j.d.roost Electric Off-Road 46 07-08-2009 07:29 PM
B4...lipo or not? (setup questions) CaptainHowdyt13 Electric Off-Road 33 02-09-2009 10:26 PM
SEO by vBSEO 3.5.0
