Old 08-16-2013, 09:41 PM   #18166
Originally Posted by Jamie James View Post
Hi All,
I did a search and this seemed like the best place to put this.
My Tekin T8 2050Kv motor seized up on me last Sunday. I was coming down the straight 2 laps into my main and all 4 wheels locked up. I had steering but no throttle.
I got back to the pits to find it would not roll.
Now the motor is over 3 calender years old, but I only put about 3 - 3 1/2 hours a year total ( yes, you read that right....3+ hrs a year.) on my equipment.
I only get out on race days and run my three 5min quals and my 10 min main.
I race about 6 races a year.
It has never been over heated and well taken care of. I'm just about to open it up and take a look.
Any guesses???
For sure open it up and look it might not be seized it might just be debrees dirt etc , i`m assuming the esc is fine right nothing burnt ? also just a tought check the diffs i had a similar problem on my scte the center diff lock up and my truck quit running i would check that first
mavdriver is offline   Reply With Quote
Old 08-16-2013, 10:04 PM   #18167
ESC is fine, nothing burnt. Motor is maintained nicely. Nothing in there.
I pulled the motor out when I got home that night. Everything rolls free. Tried turning the motor by hand...seized up tight. Even using a pair of pliers wouldn't budge it.
I opened it up and this is what I found. I'd say it's done. Weird. I know it's old calender wise, but it has what I would assume to be very little run time. I'm picking up a 1900Kv tomorrow.
Proudly Sponsored By
Maclan Racing.
TLR 22 2.0 (x2) / TLR 4.0
Jamie James is offline   Reply With Quote
Old 08-16-2013, 10:29 PM   #18168
yep is done looks like the windings let go , rotor seems fine , i would still send it in maybe Tekin guys can chime in and advise
Old 08-17-2013, 10:27 AM   #18169
King DORK's Avatar
Trader Rating: 31 (100%+)
I try not to nag very often, and last time I asked I received no response, so any word on any kind of hand held programmer? There was once mention of one with no hint of a eta, but that was quite a while ago.
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Old 08-17-2013, 11:39 AM   #18170
Krio's Avatar
Trader Rating: 150 (99%+)
The magnets came off the rotor, but it looks clear otherwise. If you can pull the magnets out along with any debris, you should be able to get that motor going again just with a new rotor. If you don't want to try, pm me and I'll make an offer for the motor as is. I have a friend who is too cheap to buy Tekin, but keeps frying the cheap stuff.
Tekin has preliminarily announced an Android smartphone/tablet app that will work with the Hotwire adapter. No release date is known, but at least we know what they consider 'better than a handheld programmer'.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 08-17-2013, 04:25 PM   #18171
Ya. You can clearly see the magnets still in the can.
I will try and get them out. Some of the winding is/has come loose. I'll get a better idea of where it's at when I get the magnets out.
I picked up a 1900Kv today.
Maclan Racing.
Old 08-19-2013, 04:36 AM   #18172
Default Auuthorization code
How long does it last, has I have had it about a month now just been busy.
LC Racing EMB-1
Losi Mini 8 Truggy x2
No Idea!! is offline   Reply With Quote
Old 08-19-2013, 03:52 PM   #18173
Default lvc question
hi, i have a question new to escale coming from nitro buggy, if i use 2200 mah in 5 minutes in a 5000 mah 4 c pak would i be able to make a 10 minute main? if used 4400 out of the 5000 mah pak?? or would it be at lvc on the esc or close? If someone could explain be great... thanks
motorhead68 is offline   Reply With Quote
Old 08-19-2013, 03:58 PM   #18174
Hoese37's Avatar
Youd probably be cutting it close. You would have to drive really smart and easy to pull i off.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 08-19-2013, 04:56 PM   #18175
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
It appears the rotor came apart. It's wrapped with Kevlar fiber so pull out the magnet segments and blow out the can with compressed air. If none of the copper wires are protruding from the stack, all you likely need is a new rotor.
If you've never opened it before, a small rock or piece of debris could have cycled through the motor snagging the wrap and causing the failure.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-19-2013, 05:01 PM   #18176
Team Tekin
Randy_Pike's Avatar
Not a "programmer" but something better. Something you will be able to choose on your own in various sizes and styles as well as prices.
Then use a Gen2 %^&* to make adjustments.
Old 08-19-2013, 05:01 PM   #18177
Team Tekin
Randy_Pike's Avatar
RMA#? Still good.
Old 08-19-2013, 05:02 PM   #18178
Team Tekin
Randy_Pike's Avatar
You should make 10 minutes but you will feel it soften at the 8 to 9 minute mark. IF you're under geared you will use more mah than you want.
What car? motor? Gearing? Size of the track?
Old 08-19-2013, 05:53 PM   #18179
randy, 2050 mtr ,tekno eb48,44/17,200x100 track ?
Old 08-20-2013, 04:55 AM   #18180
RMA#? Still good.
Ok thanks for the reply
LC Racing EMB-1
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Team Associated 1/8 Electric Buggy Info and Tips Kevin Boyle Electric Off-Road 812 09-02-2013 07:22 PM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 336 12-14-2009 10:22 PM
Losi 8ight 2.0 E-buggy Stinkweed Pete R/C Items: For Sale/Trade 6 07-02-2009 07:46 AM
Tags
1900 vs 2050?
