Tekin RX8 1/8 Scale Brushless ESC Thread
I also checked if it's the BEC but it's not, I connected the red wire coming from the ESC instead of the BEC and it's doing the very same. The other thing is that I didn't change my setup since a long time and was always running with reasonnable temps and had no problem at all for now so it's not related to a change of lipo, servo, BEC or whatsoever.
An interesting thing but it might not have any relation is that when I connect the RX8 with no external BEC the servo acts VERY slowly (it's a HV savox).
Now I will try with another T8 1400kv and with a "normal" servo (not high voltage). But there was a blitz before the ESC displayed the error message. It happened when I connected my lipo before I turned the RX8 on. So something must have gone wrong with the controller.
Hi randy can u pls tell me when the rotors for 1/8 buggy motors r going to be back in stock
Thanks jimmy
Thanks jimmy
I just checked them and everything is fine. I turned the ESC on again and the led 1&2 and 6&7 are blinking (error message of a wrong motor type selected) and the ESC is doing a regular little noise like a "t t t " with a one second interval. I don't want to accelerate with the transmitter as it fried my last RX8 when doing so.
Use a volt meter or a receiver pack to test.
Has anyone sent in a RX-8 when in has been out of warranty??? Trying to figure out the cost of repair for one. I have one left that is still running. It was run in a friends car and he told me that the BEC feels like it is going bad.
http://www.rcdisco.com/graphics/part...tor_01medm.jpg this is the rotor I was asking about has tekin USA got them in stock or do I have to wait until tekin euro gets them back in stock to buy one
Cheers jimmy
Mine with a bec and wobbly negative post cost about $45. Pretty sure there is a general repair price list on the rma or warranty page... somewhere.
I'd go to the source for this answer. Oh, that's right, everything on the internet is true!
their the kevlar raped ones
Cheers jimmy
Cheers jimmy
Cheers jimmy
Cheers jimmy
This is straight from tekin euros website https://www.google.com.au/url?sa=t&r...46226182,d.aGc
I did a forum search and didn't come up with anything.
My question is what number values are associated with each setting on the RX8? It says Drag Brake 1-13, but what are the %'s? 1 means "OFF", but what do 2-13 mean? It's the same for Brake Strength, Limiter and Neutral Width. Is each number 5%, or 10% or ??? I really don't want to purchase a Hotwire if I don't have to. I'm only a casual racer.
I read and re-read the manual, and couldn't find it. Does anyone know, or know where I can find this information?
Or can anyone give me the corresponding #'s to the following set-up?
Drag Brake - OFF
Brake Strength - 80
Limiter - 80
Neutral Width - 15
Please give me the settings (1-13) for each of these, or something close.
Drag Brake - OFF
Brake Strength - 80
Limiter - 80
Neutral Width - 15
Drag Brake - OFF
Brake Strength - 80
Limiter - 80
Neutral Width - 15
Drag Brake - OFF
Brake Strength - 80
Limiter - 80
Neutral Width - 15
