Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-02-2009, 09:53 AM   #601
Trader Rating: 54 (100%+)
Ordered my Tekin today at Amain. Go Tekin! lol
Where ever I may roam
Bigcheese is offline   Reply With Quote
Old 04-02-2009, 11:36 AM   #602
pq49x's Avatar
Trader Rating: 41 (100%+)
Randy when will the Tekin 4s 5000 lipos be ready?
Puddin, Team Sweeno, 475 Designs
pq49x is offline   Reply With Quote
Old 04-02-2009, 12:08 PM   #603
yzracer758's Avatar
Originally Posted by pq49z View Post
I would rather wait for a system that is built rite than a system that needs to be updated twice after it is released. Randy you take your time and make it a great system. The more people that buy MMM means more RX8 esc for those of us who want the best.
Ditto, I bought a MMM cause I couldn't stand just looking at my D8E sitting there. As soon as the RX8 is released, you'll be seeing a MMM combo for sale!
Hot Bodies | HPI Racing | Team Tekin | Diggity Designs | AKA | Thunder Designs | Kal-Gard Products | Thunder Power RC | Elite RC Products
Hot Bodies Ve8
Hot Bodies D4 WCE
yzracer758 is offline   Reply With Quote
Old 04-02-2009, 06:43 PM   #604
Seeing the motor shaft length is 71mm, would it be able to fit into the EX1 Pro?
Current: Tamiya TT01D, TA05-IFSR, Spy car, Caster F8T, Caster EX1 Pro, Kyosho MP9 E Conversion, MBX6T-E M-Spec.
adrictan is online now   Reply With Quote
Old 04-02-2009, 10:54 PM   #605
Randy, let me know if it fits. I'll make an order if it does.
Old 04-03-2009, 04:49 AM   #606
Key
Key's Avatar
Tekin:
Why have you chosen to go sensored during start-up when nowadays sensorless-based software is just as smooth or smoother. When u look at high end sensorless esc's in most cases they are built and work much smoother than sensored even during startup.
Can u not focus on refining your software to master the startup rather than relying on sensored hardware, cables, etc..?
Kyosho Inferno MP9 -- AKA -- O.S. Speed
Kyosho Inferno MP9e -- AKA -- Orion Vortex 8
Kyosho Inferno SCRRe -- Tekin RX8
Kyosho Lazer ZX5SP -- Tekin R1 Pro
Futaba 4PK
Key is offline   Reply With Quote
Old 04-03-2009, 05:04 AM   #607
jhautz's Avatar
Originally Posted by Key View Post
Tekin:
When was the last time you drove a sensored setup? I dont personally find your statment to be correct at all.
Yes I agree sensored is very good now, but no way is the start up smoother than a sensored setup.
The R1Pro ran very well in my buggy. Every bit as smooth of a start up as any other sensorless esc I have driven, so I dont think its a matter of they cant make the software. Its a matter of making the best possible setup with 100% perfect and consistent startups every time.
jhautz is offline   Reply With Quote
Old 04-03-2009, 05:54 AM   #608
Key
Key's Avatar
5 years ago I used to run a 1/10 on-road on 4s using a Schultz U-Force 75/Plettenberg extreme (quad-magnet) combo. Later down the road I was keen on giving sensored a try, so I ran a GTB on 2s.
Power aside, if you ask me which one was smoother at startup it would be the UF-75/Plettenberg combo hands down.
The sophisticated software of the UF at that time along with higher voltage plus the high-end Plettenberg 4-pole motor design contributed greatly to the application's 'smootheness' during startup.
If Tekin were to focus more on mastering startup using software rather than applying xtra wire harnesses I'm quite sure that start-ups can be perfected without relying on sensors.
..just my .002 cents based on what I've tested so far.
Futaba 4PK
Old 04-03-2009, 11:10 AM   #609
BlackedOutREVO's Avatar
Trader Rating: 29 (100%+)
For one, comparing a pletty to a novak is like comparing a Ferrari to a Toyota. 2 it was a novak ESC, there pretty much a on and off switch!
I think you need to try out sensored again with a ESC that works. Randy Pike let me drive his 8th buggy with the RX8 combo in there, and there is no way sensorless compares. Ive used most of the motors and ESC's out, from a few years ago running Quark, MM on a external BEC, to the MMM. You just cant beat a sensored system, you can make it close, but sensored is always. consistent, which is what you need when your pushing your car when racing.
Owen RaCing/MO Paints/Speedworld Raceway/Fighting Cock Energy
BlackedOutREVO is offline   Reply With Quote
Old 04-03-2009, 11:24 AM   #610
UK.hardcore's Avatar
Silky Smooth=Sensor.
Will never change.
I'm gonna get me a 1350Kv truggy combo.
ой8Te, D8Te, XT8e.
I think i like E-truggies.
Brushless or burst!
UK.hardcore is offline   Reply With Quote
Old 04-03-2009, 11:29 AM   #611
snellemin's Avatar
Ditto!
Novak ESC's are mostly overpriced budget equipment. You get what you pay for.
My smoothest sensorless setup is the qaurk esc with a hacker motor. But as smooth as it is, it's still not as smooth as a good sensored setup.
2 KiloWatt A123 Racer
Snelle-RC
snellemin is offline   Reply With Quote
Old 04-03-2009, 12:16 PM   #612
Key
Key's Avatar
The GTB is considered a competition ESC and is a valid comparison against all other sensored-based rivals - although I agree with your statement about the two motors.
If I had used a 2s setup on the Pletty/U-force the smoothness comparison between the GTB and UF would be very close. The point is when using higher voltage (eg. 4s+) and motors designed with more than 2poles the smoothness of sensorless are neck and neck with their sensored-based rival.
I would not underestimate the smoothness of sensorless technology nowadays. There’s much more room for improvement in sensorless than a sensored-based platform due to its 100% reliance on software.
Again, I am sure if Tekin focuses more on improving their algorithm sensors will be a thing of the past.
Futaba 4PK
Old 04-03-2009, 12:56 PM   #613
Zken's Avatar
Sensorless is awesome. We spent ALOT of time working on the sensorless design. We wanted/needed/required relaible, consistant starts for every application 10th scale Offroad, TC ( TC has ZERO tolerance for hesitations on carpet) and so on....Any input power any time anywhere....you get that with sensored.
All of the RX8 testing for the better part of 2 years was sensorlesss and it ripped. Still you get the chattered starts from time to time...this was on 2s, 4s, 5s and 6s with a 12pole motor.
We love the hybrid solution of sensored starts followed by the efficient sensorless drive through out the rest of the RPM range. This Hybrid mode or "D2" Dual Drive Mode is the basis of the RX8, RS systems and has proven to achieve the best of both worlds for any application it has been fitted to.
Key has some good points...sensorless offers a vast amount of possiblities due to it being driven via software...The starts are good but when you need %100 all the time, everytime, no matter what....you let sensored step in so that way the ESC knows exactly where that motor is sitting and how it will roll the motor the direction you tell it to.
CYA at the TRACK!! WOOHA!
Zken is offline   Reply With Quote
Old 04-03-2009, 03:22 PM   #614
markhat250's Avatar
So everyone is jumping ship from the MMM to the un-tested Tekin sensor'd?
I'm not seeing a crazy benefit to completely jumping ship right now. I've got no complaints with the MMM. In fact, nothing but praise here.
Curious to see all the Tekin hype translate into track reliability. If it is, then it could be real cool.
MUGEN SEIKI: Mbx6 & Mbx6T w/ Werks B7, Picco .28
JAMMIN: CRT.5e, SCRT10
ASSOCIATED: B4
HPI: Blitz
markhat250 is offline   Reply With Quote
Old 04-03-2009, 03:35 PM   #615
Kings Kid's Avatar
Trader Rating: 25 (100%+)
the Tekins are tested in race conditions by there team racers.The mmm's were tested in monster trucks in non race conditions which is why it three versions to get them right.
Kings Kid is offline   Reply With Quote
Forum Jump
Team Associated 1/8 Electric Buggy Info and Tips Kevin Boyle Electric Off-Road 472 03-18-2010 01:19 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19487 03-16-2010 06:57 PM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 336 12-14-2009 09:22 PM
Losi 8ight 2.0 E-buggy Stinkweed Pete R/C Items: For Sale/Trade 6 07-02-2009 06:46 AM
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
