Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-03-2009, 12:02 PM   #5401
bohdi's Avatar
Originally Posted by blade329 View Post
+1. Customer service can be rough. Most customers are reasonable people, but you will always get those few that are difficult to deal with. I used to work on cars a while back, and I've seen some crazy customers. There are those that just can't be reasoned with.
+1
AE RC8Te
AE B44
AE T4
Losi 8ight-e
Tekin RX8
bohdi is offline   Reply With Quote
Old 11-03-2009, 12:48 PM   #5402
This may seem like a dumb question but which way around does the fan go? Sticker up or down? The manual indicates that the fan is pre-installed so that wasn't any help.
slawsonb is offline   Reply With Quote
Old 11-03-2009, 12:59 PM   #5403
fullsyzz's Avatar
Trader Rating: 17 (100%+)
Install the fan with the sticker down.
fullsyzz is offline   Reply With Quote
Old 11-03-2009, 01:18 PM   #5404
Old 11-03-2009, 04:55 PM   #5405
Originally Posted by losifiend View Post
My 1700KV system took a good beating at the park this weekend and came back home asking for more. I'm comfortable enough in its reliability now, with the new board, that I might even sell my spare MMM V3 ESC.
Oh yeah, and I agree that 20C is more than sufficient. These systems are very efficient.
I am new to lipo's.Can I run a 20c 4s on a Tekin 2050 combo Losi 8B or should I go higher?What does tekin advise?I was thinking I would need a 25 or 30c?
shawzie is offline   Reply With Quote
Old 11-03-2009, 06:22 PM   #5406
rcflgator's Avatar
need some advice on hotwire, is this a must for race tuning? any info will help. looked on tekin website but not much info there
rcflgator is offline   Reply With Quote
Old 11-03-2009, 06:24 PM   #5407
20 SMOKE's Avatar
Trader Rating: 30 (100%+)
you can use but it is recommended to use no less than 25
Team HighVelocity Racing_Xray_RC America_SMC_Team Tekin_JR Propo_Protoform
20 SMOKE is offline   Reply With Quote
Old 11-03-2009, 06:24 PM   #5408
rwhisen's Avatar
For fine tuning, yes it is a must. For setting custom low voltage cutoffs, yes it is a must. For playing around with stuff you probably shouldn't mess with, yes it is a must!
There = The car is over there.
Their = That is their car.
They're = They're not racing that car.
Your = That is your car.
You're = You're not driving it.
rwhisen is offline   Reply With Quote
Old 11-03-2009, 06:29 PM   #5409
20 SMOKE's Avatar
with rx8
updates(every so often)
timing (not to much)
custom LVC
other than that not much for the rx8 but it is nice to have
Old 11-03-2009, 07:02 PM   #5410
Swen's Avatar
It depends on what mah rating the battery is. The mah x c rating is the power output of the battery. Let's say the battery is a 5000mah 20C it will put out 100amps. 25C is 125amps. 6000mah x 20C is 120amps... get the idea? I haven't heard the amp draw of these motors so I can't say what they require. Maybe Randy or Ty can help with that.
Jon Carlson
O'Donnell, Futaba, Checkpoint
OS Engines, BB Mods
Fastlane Graphix, Muchmore
Swen is offline   Reply With Quote
Old 11-03-2009, 07:12 PM   #5411
I was going to run a 4s 5000 mah which would be 100 amps,I would also like to know what the output of the motor is as well and what they reccomend.
Old 11-03-2009, 07:28 PM   #5412
marine6680's Avatar
The burst rates are more important really. If you are pulling 100 amps all the time, a 5000mah pack would be dead in 3 min. The higher constant C rated batteries help keep batt temps low and that improves efficiency. But a higher burst rate prevents damaging the pack or starving the ESC of amps and hurting your performance.
marine6680 is offline   Reply With Quote
Old 11-03-2009, 09:05 PM   #5413
marine6680's Avatar
Question...
Are the solder tabs on the motor far enough apart to use the male 6.5mm bullets soldered straight to them? If not how about the 5mm bullets? I would prefer the 6.5mm. If not I suppose a short piece of wire could be used to attach them.
Old 11-03-2009, 09:18 PM   #5414
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I've tested with low c packs like 20c. I reccomend at least 25c or higher. You get what you pay for with batteries now a days so make sure it's a good pack.
The solder tabs "could" be used with 4mm connectors on them but I wouldn't reccomend it. I wouldn't take the risk of an uneccessary connection.
Randy Tekin Team Manager
Tekin Setup Page: http://www.teamtekin.com/hotwire/ESCsetups/
Randy_Pike is offline   Reply With Quote
Old 11-03-2009, 09:34 PM   #5415
Originally Posted by eternaldragon View Post
Would anyone happen to know if this is a good starting point for a Revo using a Tekno kit?
Narrow 2-speed gear set
36T spur gear
17T clutch bell
2200KV Truggy motor
5s 35c 5000mah lipo
It says it should have a top speed of around 45mph (18T CB works out to just over 47mph).
I'm trying to find a fitting that will run well and be just a little faster then the nitros.
Kind of an off topic, will these servos be good enough?
Hitec HS-5645MG for the steering
Hitec HS-5625MG for the brakes
If so will the RX8's BEC be able to handle them or would it be better to get a separate BEC?
Sorry I meant the 2250kv Truggy system. The quoted post should have looked like this.
36T spur gear
17T clutch bell
2250KV Truggy RX8 system
5s 35c 5000mah lipo
The speed calculator says it should have a top speed of around 46mph (18T CB works out to just over 48.7mph).
Kind of an off topic will these servos be good enough?
If any one knows if the above setup is OK it would be a great help.
eternaldragon is offline   Reply With Quote
Forum Jump
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 18865 11-18-2009 04:00 PM
Team Associated 1/8 Electric Buggy Info and Tips Kevin Boyle Electric Off-Road 232 11-15-2009 10:35 PM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 335 07-03-2009 09:20 AM
Losi 8ight 2.0 E-buggy Stinkweed Pete R/C Items: For Sale/Trade 6 07-02-2009 07:46 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
