Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-09-2009, 04:01 AM   #3571
Originally Posted by Randy_Pike View Post
Bambam: Make sure to press the servo lead end together well. If one lead doesn't get good connection it won't communicate. Once connected the RX8 led tree should flicker.
Make sure you've got the lastest software:
www.teamtekin.com/hotwire.html
Thanks for the reply, I was going to call during the week but it is sunday here and I wanted to play with my new toy Tried connecting/disconnecting a few times but no joy and its got the latest software.
Anyway, I put it in the car and soldered it all up and it works fine, well actually, awesome. I was able to program it pushing buttons, the only problem I am going to have is that I have it reverse rotation and the only reverse rotating option has reverse gear which I cant race with. But that is not a problem at the moment. I will be in touch later
Pat
BAMBAM cheapsk8 is offline   Reply With Quote
Old 08-09-2009, 10:19 AM   #3572
-R2-'s Avatar
Ok so I did what I was told to do by your tech service by switching the A and B over to reverse the rotation of the motor since my ESC since my repaired ESC does not have the code 7 and went to Milestone park to run at the JBRL event on Sunday but I could not even put 5 minutes of practice with my car. I tried two ways 2s and 4s and still could not run the car without shutting the motor off the servo was working but the motor would stop at certain areas of the track, had a run to a jump and the motor shut off right at the jump and fell out of the air upside down and I landed right on the wing into the face of the jump and broke the shocktower in half people said it thermaled but the temp was 120 and I only managed a couple of laps so I knew it was not a thermal problem.
My system just does not work at all, so I'm home today and not racing and not representing Ofna along with my teamate because his ESC was being repaired also, my boss told me to go with the Mamba system and I was being stubborn because I thought I was getting a far better system and one of my managers has been running his 9e at West Coast rc over and over again and has been waiting for me to go run with him and he just laughs at the fact that I'm still down.
So I guess I need to send everything back again for the full check up again beacause the fan is still not working along with the 2 problems that I have now. Mine is a lemon please help me with problem I wish to get this thing running without any problems, it seems people are likng the product but I'm on the other side of the window. I've been more than patient when I call to get answers and I get alot of oops answers and I've had other products not work out of the box on the first day and needed to send it back and problem was resolved on the first repair but this is the has been my most frustrating product I have delt with.
Dj
Ofna racing
HYPER SC10 4X4
HYPER 9e,HYPER 9-JL PRO.21,BYRONS ORIGINALS
JAMMIN X2 CRT-PICCO EVO II,
DJ OFNA proud customer service tech.
-R2- is offline   Reply With Quote
Old 08-09-2009, 01:45 PM   #3573
NitroLuver's Avatar
Trader Rating: 16 (100%+)
I was witness to this yesterday the car did infact keep cutting power after about 5 minutes of running and was still cold enough for me to place my fingers on it for several seconds. I wish you luck DJ hopefully the esc will come back working for ya this time
www.casterracingusa.com
www.protwistermods.com
SikWitIt Racing Team(Jayson)
Caster K8-T-OS Speed
Caster ZX-1.5R- OS Speed
NitroLuver is offline   Reply With Quote
Old 08-09-2009, 05:03 PM   #3574
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I'm confident your unit didn't thermal in 5 minutes, thats near impossible. What may have happened is that a voltage cutoff setting could be wrong, possible a loose connection.
The fan will only come on when it needs to. 120 isn't hot enough for the fan to come on yet.
Please contact support@teamtekin.com or myself so we can get this resolved: Rpike@teamtekin.com
Randy Tekin Team Manager
Tekin Setup Page: http://www.teamtekin.com/hotwire/ESCsetups/
Randy_Pike is offline   Reply With Quote
Old 08-09-2009, 05:28 PM   #3575
big greg's Avatar
Trader Rating: 44 (100%+)
ive had a bad week, first my 2250 truggy motor, now this on my 2650 motor, ran fine through a pack today, geared down a couple teeth and revved it a bit and it came to a hault!
losi 8 T8 2250 "T" MMM
losi 8T 2.0 T8 1550 MMM
hobbycity zippy packs
try em out they arent bad!!!
rcproduct designs rocks!
big greg is offline   Reply With Quote
Old 08-10-2009, 05:36 AM   #3576
yfzracer912's Avatar
Well I finally finished installing the RX8 in my 8ightE. I only ran it for a minute to make sure it ran. I am still waiting on my charger. Man that thing takes off on pavement! It pulled the front wheels off the ground!!
Now I am going to set up the RX8 with the Hotwire but what should my 5s lipo cut off be? 3v per cell(15v)? 3.1(15.5v) or 3.2(16v)? I think in my slash I run it at 3.2 per cell(2s = 6.4v) But for a 5s that .1v adds up.
And 2 battery placement. I have seen pics online of buggies and truggies with their batterie leads coming from the back of the pack(nearest to the esc) and I have seen some coming from the front of the pack/car. I have super long leads on my pack so I am wondering if mabe they have to come out from the front. If not I can take like 6inch of wire off.
yfzracer912 is offline   Reply With Quote
Old 08-10-2009, 05:49 AM   #3577
kufman's Avatar
I would recommend 3.2V/cell.
kufman is offline   Reply With Quote
Old 08-10-2009, 06:56 AM   #3578
Deej's Avatar
You can run your battery either way, it's not a big deal... but it will be less resistance with shorter wires going to the battery and motor.
DJ
æ
Pull down your pants, and slide on the ice!
Deej is offline   Reply With Quote
Old 08-10-2009, 07:19 AM   #3579
East Bay Pete's Avatar
I bought the RX8/T8 2050 kv combo for my new Losi 8 2.0 back in the middle of May. Aside from the rotor problem, which was quickly fixed with a replacement rotor from Tekin, I have had 3 different ESC's fail. The first unit lasted about 3 weeks which was about a total of 2 hours of run time. I sent that back and the cause was a broken inductor.
A month later I received a new RX8 from Tekin. The replacement didn't do so well and died in about 45 minutes of run time Again, the inductor had broken off.
Two weeks later I received my 3rd RX8. I ran it yesterday for 18 minutes before...you guessed it...failure number 3! I'm not sure if this is the inductor again, because this time all of the lights still work, which is different from the other times, but there is no response from the motor. I thought maybe it might be the motor, but another guy in my club had the exact same symptoms with his failed RX8, so I assume the motor is ok. (All the connections are good.)
So, I asked around at my club and every member that bought the Tekin combo has had the controller fail. In fact, none are currently running them because they are all in for repair. The only other person running a Tekin yesterday (a replacement unit) had his die in 4 1/2 minutes of run time. None of us know anyone that hasn't had a RX8 fail.
Losi 8ight 2.0 Losi Conversion Tekin 2050 Combo 4S
Losi 8ight-T Tekno Conversion Tekno Neu 2200 MMM 4S
Kyosho eEvolva 05 Tekin T8 / Tekin RX8--Track Car
Kyosho eEvolva 05 Castle Creations 2650 Combo 6S--Drag Race Car
E-Revo Tekno Neu 2200 MMM 4S
East Bay Pete is offline   Reply With Quote
Old 08-10-2009, 07:37 AM   #3580
kufman's Avatar
Ouch!
Old 08-10-2009, 07:56 AM   #3581
RBMike's Avatar
Ya, mine was the 4.5 minute one which is one minute longer than the last one ran.
-EMBX6,T8 1400, RX8, 6S Lipo ,Elite-RC (race)
-EMBX6T,T8 2000, MMM, 5S Lipo ,RCPD
-EMBX6,T8 1900, MMM, 5S Lipo ,RCPD (practice)
-B44 (Novak)
-RC12R5.1 (Tekin)
RBMike is offline   Reply With Quote
Old 08-10-2009, 08:36 AM   #3582
Randy_Pike's Avatar
We're looking at each an every failure. I'm sorry to hear that you guys are having issues.
We have great customer support but this is not the best way to prove it! LOL
Seriously though, we will get on top of it. If there's a probelm, you know we will not only take are of you, but we will fix it and move on. We want all of our customers to be satisified, it's our goal.
Greg, that is the old rotor design. Please contact me here with your full contact info and address: Rpike@teamtekin.com
Old 08-10-2009, 08:52 AM   #3583
glassdoctor's Avatar
I know someone (avrcguy) who has run his RX8 all summer without an issue, except for the rotor that slipped back in early May and was replaced right away. Since then, it's been all good for his setup.
I have not run an RX8 myself, but I have been running a Tekin 1900 motor with my MMM
glassdoctor is offline   Reply With Quote
Old 08-10-2009, 09:04 AM   #3584
Randy, I run the Ver.1 Buggy motor. Would I be able to get a replacement rotor first before it really drops out or do I really have to wait for it to drop out?
Current: Traxxas Bandit VXL, Tamiya TT01D, TA05-IFSR, Tamiya F103 15th Anniversary, ABC Genetic, Spy car, Caster EX1 RTR, Caster F8T, Caster EX1 Pro, Kyosho ZX-5 SP, Kyosho RT5.
adrictan is offline   Reply With Quote
Old 08-10-2009, 09:59 AM   #3585
teeforb's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to teeforb
Dj
Ofna racing
Hey -R2-, will u be at westcoast this Wednesday? Im thinking of racing down there with my Tekno/Tekin setup. Still in the air if i go or not...
* Mugen MBX6T -- TEKNO Conversion -- Tekin 1700kv System on 5S
* Losi E-8ight-B 1.8 -- TEKNO Conversion -- Tekin 1900kv System on 5S
* Mugen EMBX5 Prospec -- Castle Creation MMM 2200kv System on 4S
* Xray M18 -- Castle something on 2S
* EMBX6 in HD action and E-8ight-T 2.0 in HD action: just YOUTUBE(teeforb)
teeforb is offline   Reply With Quote
Forum Jump
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 18865 11-18-2009 04:00 PM
Team Associated 1/8 Electric Buggy Info and Tips Kevin Boyle Electric Off-Road 232 11-15-2009 10:35 PM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 335 07-03-2009 09:20 AM
Losi 8ight 2.0 E-buggy Stinkweed Pete R/C Items: For Sale/Trade 6 07-02-2009 07:46 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
