Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-26-2009, 06:15 PM   #2671
R-E-A-P-E-R-'s Avatar
Agreed that the CFM's will be much lower than its 12v rating but probably close to what the stock fan pushes to begin with. And I dont think ill have any brokin blades after the first battery back with this one.
----- Caster EX-1 - Caster F8T - Caster ZX-1.5R - Caster F18 -----
---------------------------- TEKIN ------------------------------
R-E-A-P-E-R- is offline   Reply With Quote
Old 06-26-2009, 09:28 PM   #2672
whitrzac's Avatar
Trader Rating: 41 (100%+)
the fan blade got cought in the guard in the first 15min of runing.
over 3hrs on it, no more fan probs...
BTW those are practice tires only, they don't even have foams
the solution to every handling problem is more power!
lets see your big orange box do that!
Eat my du... CARPET FUZZ!
whitrzac is offline   Reply With Quote
Old 06-26-2009, 11:58 PM   #2673
glassdoctor's Avatar
6v bec voltage won't hurt the 5v fans... I've also run 12v fans on 4s (14-16.8v) without an problem. I think most of the fan failures are just from impact/abuse of running in an offroad car. Maybe we need to see some type of damping system (maybe o rings?) to help them survive the abuse.
glassdoctor is offline   Reply With Quote
Old 06-27-2009, 12:07 AM   #2674
Wht happens when the fans burn out or are damaged? There won't be any replacements sent?
Current: Traxxas Bandit VXL, Tamiya TT01D, TA05-IFSR, Tamiya F103 15th Anniversary, ABC Genetic, Spy car, Caster EX1 RTR, Caster F8T, Caster EX1 Pro, Kyosho ZX-5 SP, Kyosho RT5.
adrictan is offline   Reply With Quote
Old 06-27-2009, 08:34 AM   #2675
So I would be good too hook up my 12v fan just past the Battery connection. That thing would seriously hum.
Old 06-27-2009, 08:44 AM   #2676
TMR CHASSIS's Avatar
Send a message via AIM to TMR CHASSIS
Why don't you just hook it up to your receiver? I run mine off my receiver and it has dropped speedo and motor temps a bunch
Raymond McCoy
TMR CHASSIS is offline   Reply With Quote
Old 06-27-2009, 10:08 AM   #2677
Yeah I am playing with all my options right now. Iam getting the same voltage from the receiver as the ESC fan output. Bur the receiver only turns on here and there. Receiver is of course on all the time. But it I can hook into the power strait from the 14.4 batteries then The esc will get blasted with air and I shouldn't have to worry about heat as much...
Old 06-27-2009, 10:20 AM   #2678
jhautz's Avatar
Anyone tried these connectors? I am thinking about trying them to replace the deans connectors. Look easy to solder, good connection and easy to use and CHEAP!
Just wondering i anyone has tried them and if they had any issues.
http://www.hobbycity.com/hobbycity/s...dProduct=9283#
Tekin: Just wanted to verify that you guys think that 4mm bullets are enough. They gotta handle at least as much power as the deans plugs right? I know that most of the development testing was done with 4mm plugs.
jhautz is offline   Reply With Quote
Old 06-27-2009, 10:28 AM   #2679
big greg's Avatar
Trader Rating: 44 (100%+)
i got these on a couple of the zippies i recently bought, the plastic is really thin and frail feeling, i dont know if they would be as good as deans
losi 8 T8 2250 "T" MMM
losi 8T 2.0 T8 1550 MMM
hobbycity zippy packs
try em out they arent bad!!!
rcproduct designs rocks!
big greg is offline   Reply With Quote
Old 06-27-2009, 10:30 AM   #2680
big greg's Avatar
on another note i got to the track with my 2250 in my buggy, it needs to be geared down a bit, its geared for like 55 mph! motor temps were great tho, around 130, MMM was seeing 190 after about 15 mins, im gonna try a 13t and see if i can meet em in the middle
Old 06-27-2009, 10:45 AM   #2681
jhautz's Avatar
Yea. I got em on some zippys too. Thats when I looked at them and thought id like to try them, but they didn't have any mating plugs in the store at the time so I cut them off an installed deans like everything else I own. Now I see these in the store and I'm wondering if anyone has actually used the plugs and if they had any issues. They seemed tough enough to me. The plastic was thin, but it felt pretty flexible and tough to me. They basically just seem like 4mm bullets that slide into a housing that acts like a handle and prevent accidental shorting and plugging them in wrong.
Old 06-27-2009, 11:48 AM   #2682
Krio's Avatar
Trader Rating: 67 (100%+)
I saw someone post on them a while back and they weren't very happy with them compared to a true deans plug. My charger from Hobbycity came with such a plug and it works fine for charging but they don't have near the fit and finish of deans and I honestly would not trust them.
Panther Racing Tires - RCProductDesigns.com
Bulldawgrc.com - Teamtekin.com
http://www.youtube.com/KriosCrea
Krio is offline   Reply With Quote
Old 06-27-2009, 12:04 PM   #2683
Default WIRE GAUGE
My RX8 came with 12awg wire for the motor. Think I can get away with 14awg on the battery plug? Its all I got
Bubonic-X is offline   Reply With Quote
Old 06-27-2009, 12:16 PM   #2684
big greg's Avatar
chris did you get my pm? are you ignoring me? lol jk dude
Old 06-27-2009, 12:43 PM   #2685
bradfox2's Avatar
Ok guys, I was looking at my options as fan as fans go today. Found some interesting things out. First off does anyone knoe the CFM's of the stock fan?
Also the fan is a 5 volt DC fan. But the RX8 is pushing 5.77 to 5.79 volts on mine. That could very well be the reason for burned up fans. We all know its not good to overpower anything. Or suffer the consequences. As many of our fans already have.
I went to the computer store today to go fan shopping. They of course had no 30mm fans. I picked up a 40mm to play with. Its 12v but the CFM's are 8.5. I hooked it into my receiver and it was working pretty good.
I only temporarily mounted it just for initial testing. I am going to fab up a funnel type mount for the top of the ESC.
Anyone have any opinions on overpowering a fan motor???
As you can see this fan looks bullet proof compared to the stock one.
Not likely, I used to run 12v fans on direct 6s power, 25v. Didnt really have any problems with the motors burning out or anything.
8ight-E 2.0, Tekin RX8 1350-T, 13/46, 6s zippy/neu power, fut. 4pk
bradfox2 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Joe..Cool , Yosh70
Forum Jump
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 18865 11-18-2009 04:00 PM
Team Associated 1/8 Electric Buggy Info and Tips Kevin Boyle Electric Off-Road 232 11-15-2009 10:35 PM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 335 07-03-2009 09:20 AM
Losi 8ight 2.0 E-buggy Stinkweed Pete R/C Items: For Sale/Trade 6 07-02-2009 07:46 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
