Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-10-2009, 08:44 PM   #1501
jhautz's Avatar
Yea, I was putting 2000 back on the qualifiers in the truggy woth the 1700 motor on 5s and around 1500 mah back in the buggy with the 1900 motor on 5s. No info on the main packs yet, I havent gotten arround to charging them. Those numbers include basically running the whole warm up time also so they will look a inflated if you calculate with 5 minutes. Probably more like 7 minutes of real run time.
jhautz is offline   Reply With Quote
Old 05-10-2009, 09:12 PM   #1502
avrcguy's Avatar
Originally Posted by Jube View Post
I have no knowledge of the medusa but my castle/neu 2200 and my neu 1512 2.5d/f can both be turned by hand.
The Medusa motors are the only ones I've ever seen that are very notchy and hard to turn by hand. Not sure why they are like this, but it's doesn't seem to hurt their performance any.
On a related note...I ran some laps this afternoon with the RX8 and my Medusa V2 2000kv since my T8 2050 is out of commission . I was really shocked how well the speed control handled the Medusa. It was surprisingly smooth and punchy even from a dead stop. I also didn't notice any issues taking off after a spinout and coasting backwards. Honestly it felt just as fast as the T8 and even after a long run the motor temps were only in the high 140's and that was without the heatsink.
I've gotta say that this speed control seems virtually perfect. I'm just a little concerned about the motors at this point.
avrcguy is offline   Reply With Quote
Old 05-11-2009, 04:18 AM   #1503
B.A. Racer's Avatar
im either gonna buy a tekin combo 2050 or buy neu 1512 2.5d/f.....but if tekins backorders takes to long ill prolly be buying the neu..but for those who have ran both or know...which one is a better choice...i heard that tekin is having problems also
Team Associated T4 13.5 brushless
Caster EX-1 PRO Tekin RX8/2050
---------DX3R---------
TEAM DRIVER FOR CASTER RACING USA/TEAM TERRIBLES/FASTLANE GRAPHIX
B.A. Racer is offline   Reply With Quote
Old 05-11-2009, 05:42 AM   #1504
XXXDad's Avatar
Trader Rating: 23 (100%+)
Lightbulb
I think the direct drive is the problem. With the shock from the car's trany breaking the rotors inside the motor. Rc Monster has a 1/8 scale Slierenchel they sell acts like a slipper.... But i'm new to the 1/8 E class. All my 1/10 electric cars have a slipper. So should the 1/8 !!?
Glenn Carlson
Losi - XXX-CR, XX-4 WED , XXX-T CR , AD2( For Sale),
8ight B 2.0 E 8ight T 2.0 Speed
XXXDad is offline   Reply With Quote
Old 05-11-2009, 05:48 AM   #1505
SachaSki's Avatar
+1 I think a slipperential from rc-monster is a must have...
One other thing I don't get is why they keep the center diff on e-conversions...replacing it with a dead simple slipper like on 1/10th scale 4wd cars would I think be just as good.... and it would solve the rear wheels backspinning problems someone talked about on this thread..
Losi 8ight - OS Recab - 3PKS 2.4Ghz
Losi 8ight - Tekin RX8/T8 2250kv - 3PKS 2.4ghz - 15/46T - 4S&5S 5000mah
www.nmbc.ch
SachaSki is offline   Reply With Quote
Old 05-11-2009, 06:48 AM   #1506
Krio's Avatar
Trader Rating: 67 (100%+)
I have close to 10 hours of runtime on my 2050 buggy motor in my direct drive RC8 with no issues, so I'm hoping the couple bad rotors were a bad batch. The backwards spinning wheels are from using too thin of a diff fluid in the center (5k in a truggy) and that is the only case I've seen. On bigger outdoor tracks I think replacing the center diff with a slipper unit would be ideal as you would have insane forward punch. However, on small, tight indoor tracks the affect of the center diff on making the car rotate is essential.
Panther Racing Tires - RCProductDesigns.com
Bulldawgrc.com - Teamtekin.com
http://www.youtube.com/KriosCrea
Krio is offline   Reply With Quote
Old 05-11-2009, 07:46 AM   #1507
RBMike's Avatar
In 1/8th scale you need a center diff & there is only 1 guy that has that rear wheel back spin problem. I have a slipperential in one of my cars & it works well but is in no way a "must have". I've been running direct drive for over a year & don't even ware out the plastic spurs. It's not a problem at all.
-EMBX6,T8 1400, RX8, 6S Lipo ,Elite-RC (race)
-EMBX6T,T8 2000, MMM, 5S Lipo ,RCPD
-EMBX6,T8 1900, MMM, 5S Lipo ,RCPD (practice)
-B44 (Novak)
-RC12R5.1 (Tekin)
RBMike is offline   Reply With Quote
Old 05-11-2009, 10:25 AM   #1508
Nope, this is not true. I have the RCM Slipperential and had the first reported rotor failure on my TX8 2650.
E-RC8 electric conversion
Hotbodies Cyclone USVTA
B44 - broken
CRC Gen-X
Stealth_RT is offline   Reply With Quote
Old 05-11-2009, 10:32 AM   #1509
XXXDad's Avatar
Lightbulb
This is great talking things out... compare notes! I take it all in, then put it all to use. Thanks Brothers.....
Glenn Carlson
Old 05-11-2009, 10:57 AM   #1510
TeamTekin's Avatar
We have now seen a few rotors slip on the shaft due to a bad glue joint, a very few out of many many motors so far. They appear to fail in the first few runs or not all. We think it is a manufacturing problem and not a design issue.
If you see the pinion get misaligned with the spur gear the shaft may have slipped. We have already made some changes to the manufacturing process and the design.
Something had to happen sooner or later. It has been a pretty amazing couple weeks with no problems. We are still smiling and will promptly take care of anything we learn from here on. Any failed rotors will be replaced immediately. Please contact support@teamtekin.com
Tekin Prez
jcampbell@teamtekin.com
www.teamtekin.com
Smarter, Smaller, Faster.....
TeamTekin is offline   Reply With Quote
Old 05-11-2009, 11:28 AM   #1511
avrcguy's Avatar
Tekin Prez
That's what I like to see. Prompt willingness to resolve issues! If only some other companies would follow suit. Thanks guys!
Old 05-11-2009, 11:32 AM   #1512
RBMike's Avatar
Hey Tekin Prez how can I get those ESC fans in bulk (maybe a 10 pack)? I had 2 fans fail in 2 days at the track.
-B44 (Novak)
-RC12R5.1 (Tekin)
Old 05-11-2009, 11:44 AM   #1513
TeamTekin's Avatar
We are selling 2 packs pretty reasonable. We can probably work out some bulk deals for people also.
We think it is mostly dirt getting in the fan. Impacts can also damage them, but they should not be able to flex enough to let the fan blades hit the top. there is a dimple in the middle of the top to hold it down also. We are looking at an air filter, but it really kills the air flow.
www.teamtekin.com
Old 05-11-2009, 12:09 PM   #1514
badassrevo's Avatar
I have a MMM V1 and the fan will last all season. I have installed one of these, http://www.rcmart.com/catalog/rc-3ra...8-p-22626.html it keeps the blades form catching the grill work and makes the fan last.
They are also available in a 25x25 size.
http://www.rcmart.com/catalog/rc-3ra...7-p-22625.html
It is the best thing I have found to keep a fan alive.
www.casterracingusa.com - Caster Racing USA
www.maxamps.com - MaxAmps Batteries
www.paintmonsterairbrushing.com - Paint Monster Airbrushing
www.BFastrc.com - Feel the Diff
badassrevo is offline   Reply With Quote
Old 05-11-2009, 12:38 PM   #1515
RBMike's Avatar
The first one just stopped working, I got a new one from your driver here. That one lost one blade in the second heat, a second blade broke in the main. On Sunday at practice the it finally stopped. I understand and am not upset but I'm woundering why you choose the same fan that fails regularly in the MMM's?
-B44 (Novak)
-RC12R5.1 (Tekin)
Forum Jump
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 18865 11-18-2009 04:00 PM
Team Associated 1/8 Electric Buggy Info and Tips Kevin Boyle Electric Off-Road 232 11-15-2009 10:35 PM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 335 07-03-2009 09:20 AM
Losi 8ight 2.0 E-buggy Stinkweed Pete R/C Items: For Sale/Trade 6 07-02-2009 07:46 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
