diy motor mod
diy motor mod
bit of help plz
im new to this rc game, but im on my 2nd car, have been playing with a 19t mod motor, 19t tuned motor and have just built a 15t mod motor with a ansmann armature speeds not to bad but it runs very hot is there any thing a can do???
thanks iceo
thanks iceo
Timing and gearing are the 2 main areas to look for if it's getting very hot. Also, mod motor's will get hot regardles if you are bashing with them for 15 minutes continuous.
gearing is 19 pinon 64 spar, 2 min max before the thremo kills esc
What type of ESC, and what type of car?
Another thing I jsut noticed, Annsman, not exactly high-performance, so that could be part of the problem...
its a dynamite tazer 15t esc, ansmann royal flash the can is from a 19t and the armature is out of a ansmann clash 15t
+1 on quality Vs price...
The Ansmaan are a rather budget motor, so the armature may not handle current flow as well as a "good" 19t or modified motor, they are made with price being the main factor.
All you can do is keep the commutator as clean as possible, and re lube the bearings frequently. Use brake cleaner (watch the paint on the can or it may peel off) on the bearings and relube with 1, (yes only one) small drop of light oil.
any more will just leak out and cause more problems with attracting dirt to stick onto the oil and foul the bearing...
ok thanks , what is a good 19t mod, as it stands i get about 4 to 5 min run on a 3700 batt. have been looking a a fire ball but they do nt seem much better than what im all ready running
hope that helps
will it be any good in a 1/10th 4wd off road st???
ansmann royal flash with a fixed 19pin/64spar
the spar can be droped to 62t but i cant find a long shaft pinon, any ideas?
You could try going away from the mod motor. A good 19 Turn Stocker would KILL a cheap 15 turn mod, and your heat issues will reduce considerably. Also, with a stock motor they generally last a lot longer before needing a Comm cut.
Even though your ESC says 15 turn limit, it's not a high performer so a higher turn motor will be a lot easier on it ensuring the ESC lasts you a while.
have you got any thing in mind, as i wouldn't know where to look and what im looking for
