JConcepts' Bar Codes - Reverse or Not?
So I understand that this is the recommended direction to mount these tires.
http://i206.photobucket.com/albums/b...c/barcodes.jpg However....I've heard reports that some people like to reverse them when running them as fronts. Just curious if someone who has tried them both ways can chime in and tell us the difference. It would also be nice to know what kind of truck they were on as well as some basic setup info. Thanks! |
Your picture does not work!
Anyway The YYY patter is out on the set that I mounted up of the rear of my T4. I was running losi pink tapers all around. on a hard pack track. "FTR in michigan" I cut the outside foam at a small 45 deg angle to fit the tire better and for a more rounded profile. I noticed more forward bite and about the same side bite on power Off power it had more side bite. over all it felt more predictable in the situation I was in. I have heard that reversing this for the front would give you more steering. I have not tried this yet. but I have plans on buying a few more gold bar codes to experiment with. Hope this helps |
Originally Posted by tdeal823
(Post 5158771)
Anyway The YYY patter is out on the set that I mounted up of the rear of my T4. I was running losi pink tapers all around. on a hard pack track. "FTR in michigan" I cut the outside foam at a small 45 deg angle to fit the tire better and for a more rounded profile. I noticed more forward bite and about the same side bite on power Off power it had more side bite. over all it felt more predictable in the situation I was in. I have heard that reversing this for the front would give you more steering. I have not tried this yet. but I have plans on buying a few more gold bar codes to experiment with. Hope this helps I'm hoping to get to use mine for the first time tomorrow, and I'm trying to decide the best direction to mount the fronts. |
I'm in the same predicament gluing these up for my T4. I saw the picture and I thought the original posters picture was correct? VVVV's on the outside, YYYY inside when gluing them up for the rears. Reversal of that for the front?
OK. I changed the pic host. All should be able to see it now.
Someone should do a simple single or double-blind test to see if the driver can truly tell if there is a difference.
http://en.wikipedia.org/wiki/Blind_experiment if you care to learn more. |
I will be buying at least one more set and mounting them in reverse.
I should have an answer for you next wed. |
It was posted in the JConcepts part off the offrad section that the "Y" on the outside for the fronts will provide better steering.
Originally Posted by Michael#81
(Post 5159377)
Plus I would tend to think the opposite might be true for fronts since the outside edge of the outside tire only touches in hard cornering. |
Originally Posted by avrcguy
(Post 5157495)
Copied from JConcepts thread
Originally Posted by d4man
(Post 5141283)
Also, which side of the tire is the outside???
Originally Posted by rdub202
(Post 5141456)
read the last couple pages bud. people are loving them. and your outside question has been answered as well.:rolleyes:
Originally Posted by tripthreat
(Post 5141581)
If you are talking about Truck Bar Codes.. it is a setup option...
However, I prefer the 'hard' side to be inside for fronts, outside for rears.
(Post 5141654)
I just noticed the buggy rears are the same on both sides :o
Thanks for your help... |
Originally Posted by X God
(Post 5160081)
Did JConcepts change the Bar Codes for the buggy ? Mine are like the inside edge of the picture on both sides
