Building my XXXT-CR >
Building my XXXT-CR
Building my XXXT-CR
Old 12-06-2008, 11:54 AM
Default Building my XXXT-CR
I am well on my way into the front clip build and am at the part where my spindles need to go on. My problem is that the pin that drives top to bottom thru the spindle, thru the knuckle, and out the bottom of the spindle. the washer that spaces the knuckle and spindle wont slide on to that pin. Am I just not pushing hard enough? I don't want to mess things up, but i've never done this before so I don't know what kind of force is okay to use.
Bump is offline
Old 12-06-2008, 12:02 PM
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
is the washer plastic ? I am looking at my cr buggy for you.
Jason Pelletier is offline
Old 12-06-2008, 12:09 PM
no. its a code "A2216" washer. 1/8 x .050. gold/brass colored washer
Bump is offline
Old 12-06-2008, 12:14 PM
I dunno this cr buggy has a plastic shim spacing the spindle.
Old 12-06-2008, 12:15 PM
dammit yes....it IS a plastic washer. was reading the directions wrong. thanks for the tip!
Bump is offline
Old 12-06-2008, 12:16 PM
NP man ! good luck with it.
Old 12-06-2008, 05:26 PM
this one may be a bit more difficult to diagnose.....
building the diff, i opened up the bag (bag D) and it had some washers to hold the diff balls down, as well as some bronze shims. I put those in and well...I have two others that I don't see in the instructions. I want to say they are .010" x 1/2". There's two of them so it may be another shim set but does anyone know??
Bump is offline
Old 12-06-2008, 05:42 PM
They are used only if you don't use the bronze colored ones under the main silver diff rings/washers. Suggest using the bronze jobs and forgetting the extra thin shims.
Dave H is offline
Old 12-06-2008, 05:47 PM
awesome. the tranny doesnt have to come back apart!
Bump is offline
Old 12-06-2008, 06:24 PM
LOL.
Old 12-06-2008, 06:32 PM
my motor cover screws have no head cut out can i get those somehow? maybe thru losi direct, or would the hobby shop have them?
Bump is offline
Old 12-06-2008, 06:46 PM
just go to lhs and buy ones that fit.
Old 12-06-2008, 11:33 PM
INLINE V's Avatar
Default RPM has a nice upgraded cover
http://www.rpmrcproducts.com/products/losi/trans.htm
Don't have one but looks like it's suppose to seal better than the stock cover.
EDIT: Doh! You meant the Motor cover/gaurd with the "TL" in it didn't you... oops. :P
INLINE V is offline
Old 12-07-2008, 02:47 AM
I'm not sure what you're saying, but if it's the rear motor guard, and you are referring to no countersinking, you’ve got something wrong. The guard on the bottom goes on top of the chassis, the countersink is in the chassis for the flatheads. The top doesn’t use flatheads so no countersink needed.
Dave H is offline
Old 12-07-2008, 04:18 AM
i've got it all put on correctly its that the screws themselves dont have the hex cut into them its nothing major, lowes probably has what i need. i can go in with the thread/pitch of it and snag a couple. i also need a good hex set anyways.
Bump is offline
