What do you use for removing double sided tape residue?
I use mineral spirits.....
+1 for WD40 let it soak a bit
sneek into your wifes bathroom and get their bottle of finger nail polish remover. Works great, been using that for 20years. Seems to be plastic safe as well.
i use white spirits on mine, removes all stickyness and drys to leave it fine for resticking. if you are worried then use a little motor spray or meths for cleaning
1st use a good servo tape like bud's. it wont leave crap like the cheap stuff that sadly looks the same.
if need to remove the crap. the quick easy way is with traction compound. yes traction compound. just like traction itself, paragon works best heh
R
R
3M has a double sided tape I get at walmart that is clear in color with red colored backing. It rolls right off without residue. Only double sided tape I'll ever use.
Here is a link showing you what it is.
http://www.officesupplieslane.com/mmm4010.html
