Old 12-02-2008, 01:57 PM   #1
Default nue 1512 2.5d and 5s
Will this combo work? If not what are the issues,heat,over reving? The 1512 2.5d is a 2000kv motor.Thinking 13 t pinion and stock mbx6 spur (?) . At what rpm do brushless motors grenade? Track is approx 180 ft straight.
Thopper is offline   Reply With Quote
Old 12-02-2008, 08:34 PM   #2
SpEEdyBL's Avatar
The 2.5D will handle 5s fine, but may be a little much for the track. Neu 15xx motors are rated for up to 60,000 rpm although they run best in the 30-50k range. For 5s I would recommend getting the 1.5y which is 1850 kv. Some people also run the 3D (1700kv) on 5s, but Y winds theoretically are a little bit more efficient. But either of the motors you choose will run cool on 5s so overheating shouldn't be an issue.
My vehicles (that work):
Custom experimental Losi 810/TEN SCTE - The fastest 1/8 scale buggy on the track - 5.2lb rtr - readily convertable to a ROAR legal 1/10 scale 4x4 SCT.
Custom Losi 8ight - lowest CG of any 1/8 buggy
Losi 22 Mid Motor
SpEEdyBL is offline   Reply With Quote
Old 12-02-2008, 09:03 PM   #3
teeforb's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to teeforb
Hey Thopper, the setup you ran of mines was a 1512 1.5y. Jus so you have a reference.
Also, try this. not sure if i sent this to you.
$$ Team High Budget $$
* Kyosho RB6 17.5, Yokomo YZ2 17.5, Yokomo YZ2 13.5, Yokomo 2015 BD7 BE
17.5 stock buggy fb page
teeforb is offline   Reply With Quote
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19920 04-03-2013 08:30 AM
Electric 1/8 Rules Debate Jube Electric Off-Road 234 02-26-2009 06:48 PM
SEO by vBSEO 3.5.0
