Novak Havoc Systems...
#62
Thanks for the info but I am not having any setup issues.I wonder if my senor wire is flaky
#63
with the 8.5 I found that the esc gets a little hot and when you start adjusting the esc (break,drag break,mim drive ect.) it tends to put a load on the esc .I would try setting it back to factory and see what happens.next try your idea (sensor wire)if it seems loose then take each plug out individually and try to make it i tigther fit,I had to do that with the harness from the esc to the rx
#64
It appears this ESC doesn't like FM radios from what I've found so far.
http://www.rctech.net/forum/electric...tting-out.html
