Fusion EX1R PRO Set up/tuning/Build thread
#17
Tech Legend
can you attach the pics to the thread? I can't get the links to work for some reason. They just don't pull up anything.
As for the 4S adapter from 2 2S packs, definitely on our own with making that. Two manufacturers I contacted were unwilling to make the adapters due to liability issues from what I understand.
#18
i would post pics to the thread if some one can tell me how to reduce the file size so i can post em here
Any ways just got home from practice with the EX1R buggy and heres what i found!! i probably drove the buggy nearly 1 and 1/2 hours straight and gave it a good a$$ kickin in the process just to see if its gonna hold up
the good:
- super smooth buggy with a very free drive train
-rear end stays planted even under hard acceleration
-jumps very well and balanced
-very good acceleration (good over all gear ratio for electric)
-tracks straight at high speeds and dosnt have a tendency to "wander"
-low CG of car and battery lay out really lets you push it hard around tight turns with out fear of traction rolling
-very stable and didnt really get upset easy, and when it did it settle's back down pretty quick and lets you get back on the gas rather quickly
-pretty confidence inspiring race car
-took a good beating,purposely over shot and lawn darted some jumps (well most of em were on purpose ) hit the wall a few times at high speeds broke one ball end( see below)
The bad:
-car has a tendency to wanna push or over steer..could be my tire choice?
-needs more steering,out doors im sure it would be fine, but for our indoor track with lots of 180's it could use a little more
-broke a steering ball link( was warned about this but i gave em a shot anyways) if i were you i would just go ahead and replace them right away with stock shock ends. once you see one you will see were its destined to fail.
the good:
The bad:
#19
Question about the RC8 body
Does it leave some of the battery exposed at the rear? I checked one out at the LHS and it didn't seem like it would be long enough at the rear.
So I didn't get one... yet.
yoshgixxer, sent you a pm
#21
I ordered my car yesterday, so it should be on it's way soon. I will be running on a tight indoor clay track www.arcshobbies.com so I will be lookin for steering as well. Please continue to post your set if you make changes.
Thanks,
Doug
Thanks,
Doug
#23
badassrevo---a good tire for indoor clay is the panther switch 2.0...the clay compound tire works good..but the soft's work better if you can afford to replace the tires every 2 or 3 races.......thats of coarse if you guys arnt running slicks
like i said earlier my car did have some push or over steer..it might of just been the medium compound tires i was running,(dont like killin good tires for practice!) im gonna run the soft's this week end just to see if it was the car or the tires...
#26
I've been hearing a lot about the Slicks lately. Are those legal to run?
#28
slicks are legal,they work great if they clay has been watered.a pair of grinded down m3 compound tire like a bow tie or crime fighter's works great...especially if you treat em with diesel
i run the max amps 6500 hc's when i need to surely last 25+ minutes, but most of the winter i will run my smc 5200 hard case lipo's.there rated at 25c so they really rip,so not a bad deal at $80 a pack
i love pink tapers too...but i hate how they last one race day
#29
Maybe that was just a local track's rules for 10th scale some years back...
I may have to get a pair to test out.
