Old 11-27-2008, 03:34 PM   #1
Default Share Your Driving Tips Version 3.0
ok, I seen this thread once and before every rce I always read this, but it hasnt been updated in over a year so I wanted to make a Share Your Driving Tips Version 3.0!!! Here are the tips from 2.0. If you have a tip post it and tell me where you want it: general, jumps, turns
party_wagon and t4ftracer
Have fun and help other racers whenever possible
Tips by AndyMoore and MarkieMark231----
Not wrecking is the single most important thing you can do.
Secondly, in practice, run a middle of the track line and then tighten it up as you feel more comfortable. This will give you a feel for both "the line" and what its like outside of the line (in case you need to make a pass there), while keeping parts breakage and wrecks down.
by XXXCRRacer
On a new track I will overview the track first before the car hits the track. I start a few laps slowly, and then I will progressively get faster, in between learning the lines of the track. Once I learned the lines then I drive to my full potential.
Walking the track during down time is a good idea.... you'll see allot of bumps and ruts and so on that you did not notice from the drivers stand
By bobf24
if you can't make a certain jump or part of a track, your better off not doing it, rather than keep trying it, even if its faster to do it, for the amount of time you save for the 2 out of 5 times you can make it, the time you loose the 3 out of 5 times is going to be at least double,
another thing Iíve found, when you get out to a big lead in a main, donít slow down, keep going at your fast pace, otherwise if you have a problem, it can be really hard to get back into that fast rhythm and make the time back up,
another tip I remember reading from Matt Francis, always try to chase down the next car in front of you, no matter if that car is 20 laps behind you, its easier to be fast if you are chasing someone, than leading someone
byjfc_tech ----
drive crazy fast during qualification. Put everything in your power to get higher ranking in the qualifying
Drive conservatively during the main final. Fast but careful. Good for 45mins to 1 hour final
Stay as close to the pipe as you can, as long as you won't case a jump that is after the turn. If you must go past the pipe the make the jump, go just wide enough, as if adding an invisible pipe to follow.
This is the way that I think of racing lines. In stock racing, your car is not moving very quickly, letís say 15 feet per second on average in a turn. If you go 2 and a half feet past the pipe, that is 5 feet total: forward, turning, and then the other way. That distance when going 15feet per second on average in a turn, will be .33 seconds slower than keeping it tighter.
I feel that it is better to go slower through a sweeper or a turn and keep it tight than to go faster and wider. This is particularly useful when following someone closely. Going just slow enough to keep up with them, you will be able to keep a tighter line and will eventually make the pass as they go too wide in a section. Just hope that their going wide won't result in you getting rear ended.
By golfinglenn
one of the best tips is to watch the faster drivers and see what lines they are using. You can also see how they are taking the jumps (double-single, triple, etc).
By MonkeyWrench
try this sometime and see what you'd prefer. Most people drive with the middle portion of their pointing finger on the trigger. "Finger wrapped around the throttle". Try using just the very tip of your finger on the throttle, you'd be surprised at how much more precise the feel of the car is and also your reactions will be faster with less movement of the finger. I have switched back and fourth depending on how I am doing in a race. And I agree with the others that less time in the air is more ground covered. Try to backside every jump and keep your momentum up through the corners. Oh and keeping it on the tires helps a bunch too
By Nay0k
if you believe you are faster than the leader, wait for an opening. Nobody is a perfect driver, and a mistake will eventually let you see an opportunity of a pass by this. It'd probably be less costly than an aggressive pass, seeing as those have the tendency to cause mistakes.
By Pull_My_Finger
learn the tendencies of the other drivers.
Some guys will not budge an inch if you make an inside move on them. These are mostly the inexperienced drivers and the results are usually a tangle-up. A good driver realizes when you got them on the inside and will allow enough room for both cars to clear a turn. Likewise do the same if you are getting passed. Once someone gets their nose in beside, it will benefit both of you to let him go on through. If you fight him for the turn you may get lucky and come out without a crash, but if you get tangled up youíre not going any where until the marshal gets there.
My driving tip is this, when going through slow traffic or passing give the guy ahead of you more room though difficult sections of the track because thatís where you will most likely catch them or thatís where they will make a mistake. You definitely donít want to hit and tangle
carbon madness
Also don't rush to pass them, as some people can't handle the pressure of a faster car wanting to go around them (normally they end up crashing). Also don't give them the bump and run after you just catch them, as you will normally be look down on, instead of being looked up to. If you can talk on the stand, ask if they will let you go around them in the next corner, etc.
Don't follow too close when you are waiting for the guy in front of you to crash, you may get taken out too. Give yourself 2 feet and occasionally close in on his bumper and fall back to add pressure.
1/8th buggy/truggy: This is something I do a lot at regional and national races, maybe itís not always the nicest thing to do, but whatever. This is maybe in contradiction to the above tip, but if you are a good driver it is not too hard. When youíre battling with another car on a high grip track I will always follow behind the guy in front of me really close. I'll follow somewhere between 6-18" behind them, and get extra close in some sections of the track, this will make the driver in front of you super nervous. If you hit the guy in front of you though you will look like a huge hack, so be really careful. This is usually good if youíre following a driver who is a bit better than you, so you can still keep up, but you will be able to learn their lines and braking points really quickly.
As hard as this sounds. I donít do it but I always try, drive the track not the other drivers. I hope that makes sense. Donít let the other drivers rattle you.
practice without a transponder, it makes you work more on your setups and you won't be trying to get just that one fast lap every run *added* this is great when working on a bad handling car but once you get the setup close use the transponder you would be surprised to learn the best feeling setup does not always produce the fastest laps
Jake S
Another one while on the subject of practice, go out when you see one of the fast guys on the track, let him pass you and just follow him around, it helps in finding a "fast line"
also another good thing is to run back-to-back (if your racing two classes...or more) during practice if its "open practice" it more-or-less helps you work on consistency....then after running both I would make changes and run another practice round.
The biggest mistake in off-road especially in 2wd is to overpower your vehicle. Until you can make it through an entire race with little to no crashes due to driver error don't make your car faster. I fast car is no good if your wrecking once or twice a lap
Something I stumbled across this Friday that will be like "duh" to some people, and "oh I didn't think of that", but you don't have to go full throttle, except on the straight. My car was ok, but I had trouble pushing it, so I ended up just part throttling through the whole track except the straight. I ran my most consistent main to date, sure my laps times were a few tenths off my fastest, but running 5-6 more laps closer together was better than blasting one fast lap followed by 3 slower laps.
When running 2wd you will have a lot more rear traction after you have had a little bit of throttle time and you will have more front traction after you have had a little bit of break time. I typically blip the throttle out of turns, not enough to lose traction, but enough to torque that rear end down, and then hammer on the throttle. Same thing for entering turns, I typically blip the brakes, not enough to really slow the truck down, so that the front end will come down and get a good bite when entering the turn.
When practicing only push your car harder if you made the last 3 or 4 laps mistake free. This will help you to learn which sections you can take at a blistering pace and which ones you need to slow down for.
Race at more then one track on a consistent basis. You will learn the lines of your local track over time, but this will not help you when you decide to travel to big races and do not have the experience needed to become quickly accustomed to the new track.
Simply put, DON'T CRASH. Kind of a 'duh' statement, but focus on learning you limititations on each layout in practice by finding the fastest you can do every part of the track, what jumps/line you can do w/o crashing. Let's call that 100%. Then back it down to 90% until you have to use that last 10%. That is something I have been doing since the Mod Nats, and has helped me a ton, thanks to Mr. Maifield for that.
See if the track owner will let the local fast guy paint the fast line on the track surface so everybody can see where they are supposed to be and where they actually are. Then, drive just slow enough that you can stay in the "fast Line".
I don't like the fast line idea, different setups and cars will be faster on different lines. Often times the fast guys setup will be completely different from yours in aggressiveness. If he is using a super forgiving setup then that point shoot ultra tight line may not be the one you want to follow if your using an aggressive setup that should be trying to carry more speed through that tight hair pin since you don't have as much rear traction*added* the fast line is pretty set if you are running a different line you either have found a new faster line or you are likely losing time
Get up on the stand and watch the fast/smooth guys. Try to copy their lines, go as slow as you have to in order to hold those lines and make all the obstacles without crashing. Also Checkout their hands.
Throttle finger is almost never pegged, always moving.
Try a mod motor in practice, stock will be a cakewalk in comparison.
Don't use a pro's setup if you don't drive like a pro.
Kit setups are easiest to drive for average racers.
Start tuning when you really know what you need.
Get help finding your setup.
Allot of times your car is just as fast as the fastest guyís car at the track, but you over drive the car. So following will smooth out your driving.
If you are consistently having trouble at one corner or section of the track, marshal that corner. You will get a different perspective on how to complete that section and it may help you out.
Most people learn from there mistakes, but there only one.
Learn from everybody elseís and your way ahead. Time old saying, watch and learn. And you donít look so silly when you have a first attempt
I'll never forget what an old timer R/C racer told me once....I was in 2nd chasing the #1 car and totally driving like a jerk....power sliding every turn, wide open all over the track just to try and catch up and make the pass. This guy was standing off to the side of the track hollered all the way over at me:
from then on...every time I get antsy on the stand, I just tell myself...."slow down" and I instantly pick up some time.
Roll the throttle
Turn your wheels in the air to setup for the approaching turn when you land the car is already turning.
Turn up the face of a jump into a tight corner this can land the car at a better angle for the next turn.
Try to downside most jumps
Land jumps on throttle or brake for different effects
Hitting the throttle in the air can bring the front up and hitting the brake will drop the front.
You do not have to square up to all jumps some are better if you take the diagonally or at other angles. Experiment.
By MustGoFaster
Take Most jumps; at a constant rate of speed and release the throttle at the top of the jump (before the take off). This should pitch your nose down just enough to downside the landing.
If the car is pushing letting off briefly then get back on throttle can tighten up the turn.
By Scrubb-----
Drive slow enough to stay in the fast line. You can only turn brake or accelerate when your tires are on the ground - so keep jumping to a minimum. Itís easier to drive fast 1 foot away from the pipes, than it is to drive accurate 1 inch away from the pipes. ---------------------------------------------------------------------
By Crim3Wav3
#1 Rule: cornering is where to gain time.
In sedan, if you drive hard through the corner, you are scrubbing speed. Lifting (off the throttle) just before the turn to load the front tires will allow you to carve through the turn and stay on the line.
In 1/8th, the same is true. If you are prone to gassing it in the corners and shooting huge roost, youíre killing yourself.
by bobf24
pass to the inside when ever possible, this is especially important for the first turn of the first lap, if there is a crash, it will always move to the outside because of centrifugal force, so if you are on the outside, the crash will swallow you up, if you are inside, the crash will move outside and your line will more often than not open up for you
By sandrixx
and in really loose, dusty track try doing the "tap-tap-tap" on the gas while turning rather than pulling it hard and having spinouts
By Jack Smash
Learn to squeeze the trigger slowly. The tap-tap-tap method is horrible for vehicle dynamics (however it is better than uncontrollable wheel spin).
*added*try both I have seen both used with great results but most of the time squeezing the trigger works better. Experiment to find what works on your track.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 11-28-2008, 04:55 AM   #2
rob martin's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rob martin
nice writeup
rob martin is offline   Reply With Quote
Old 11-30-2008, 06:19 PM   #3
Originally Posted by rob martin View Post
nice writeup
I cant take credit for this, cmain creasted a thread like this only version 2.0.
HERE is the link to where he made it, just thought it needed a little revision.
Any tips?
Old 12-01-2008, 08:02 AM   #4
tom_chang79's Avatar
Consistency is the real key to winning (or finishing at the very least).
What I do during practice is that I run the first few laps slower then usual and get used to some of the nuances of the track. Then I start pushing the car a little harder then these warm-up laps to see how I respond and my car responds...
If you are flipping your car or ramming your car into the wall, it's time to slow down.
Back to the consistency thing, once you find the best way for YOU and YOUR CAR around corners, jumps, and other obstacles, repeat it exactly the way you have done it.
During a race, try not to focus on other racers and their cars. Many beginners don't understand but it's you against the CLOCK, the other drivers just happens to share the same facility with you...
tom_chang79 is offline   Reply With Quote
Old 12-03-2008, 08:24 PM   #5
bump!! I know there are some more tips!
Old 12-03-2008, 09:19 PM   #6
carbon madness's Avatar
Their are differnt set-ups that feel differnt on the track, as every drive likes to drive a little differnt then the guy next to you. So if one persons set-up is night and day differnt then yours, but you are still working on driving a little better, keep in mind your set-up might be just as fast as the other guys or it could be even faster then his once you learn to push the car a little harder. It might be tempting to switch to their set-up but that might hurt you in the long run, as being that every one likes their cars to feel a certain way.
I for one tend to like my car to rotate through the turns, but have a nice rear end grip feel with maybe a light push (for off-road), while the guy next to me might have the same car they might like the rear end on the free end with a car that cuts through the turns. The bigest thing is as long as you can drive consistency around the track with some fast lap times, and you like the over all feel of the car then that might be the set-up that you want to run eventhough the other guy might be running a differnt set-up.
Also sometimes it is just that that other guy found a line around the track that might save a few tenths in some turns and that is why they are pulling away from you, not because their set-up is differnt.
(wo that was a lot of typing for me, lol)
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 12-04-2008, 06:49 AM   #7
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
+1 for consistency...you're not going to catch anyone, or impress anyone for that matter if you're parking it on a pipe every lap. Slow down, give yourself a little room in the corner and focus on driving the line. The speed will come on it's own.
Chris Woods
TQ Racing Wire
mafiaracers is offline   Reply With Quote
share your driving tips Version 2.0 cmain Electric Off-Road 33 08-01-2008 12:57 PM
SEO by vBSEO 3.5.0
