VXL vs. Mamba Max vs. ORION Vortex
Which one is better? VXL, MM or LRP
I dont really have a budget limit so feel free to talk about other BL systems
looking to put it in a rusty or pede
I would highly recommend the Tekin R1 with the Redline 632 or 537 motor. The speedo has so many great features and can be tuned pretty much any way you like. The onboard programming works fantastic. I put this setup in a Slash for bashing around and it is a lot of fun. It has a lot of torque so you can gear up. if you are looking for extreme speeds you could use the R1 Pro with a faster Redline motor but the R1 is less expensive than the Pro and has all of the same features. Although it does have the 5t limit but that is plenty quick
Tech Legend
for bashing, I would give a nod to the MM as you have A LOT of adjustability in the ESC and its pretty robust. If running mod, I would also not have any issues running a MM system. Currently though for lower kv classes like stock it doesn't run the motors as well as sensored systems. I believe Castle is making a sensored ESC however.
Tech Legend
Trader Rating: 51 (100%+)
mm7700 if you try the search feature you will find so many threads on what speedo is better its scary!!!!!!!!!!!!!
Trader Rating: 45 (98%+)
Hi guys, may i know if I pair up MM with Feigao 9XL is a good idea for Jammin CRT.5? May I know MM do have output for the cooling fan and built in Lipo cutoff? MM max can use 3c Lipo, right? Thanks.
Tech Legend
To me bang for the dollar is it just tough to beat a Sidewinder system. All the systems out for the most part are very good. Are 3 local shops all support Castle and a few other brands as well. The owners do a great job also explaining the whole ROAR thing to customers before selling brushless systems.
