Pico Xp-12 Carb settings?
Hey guys,
If you happen to know the starting carb settings for a pico xp12 slide carb rear exhaust engine please post them here. I havent had a chance to run my truck in a few months and last time i did it wasnt running quite right so i want to start from scratch. Thanks, Blake |
Blakesrc;
From the Picco XP12 manual: "High Speed Needle - 1-1/2 turns out (tighten needle all the way down, and then turn back out) Setting may need to be higher for break-in (engine should be run richer for break-in)" "Low Speed Needle - 3 to 3-1/2 turns out (done with the carburetor in the open position, tighten needle all the way down, then turn back out)" * Use care NOT to overtighten the Needles when closing them fully) * |
