Old 11-08-2008, 04:08 AM   #1
Default Advantages of 78 tooth spur in a B44 ?
I've noticed alot of factory guy's are running a 78 spur in their B44's with a 7.5, What is the advantage compaired to the stock 84 ?
Lou Colmo/Tekno EB48.3, SL & SCT410.3/ Tekno R/C,Tekin / Reedy Batteries / Savox /AKA / Futaba 4PKs
Blaze R/C,St.Louis DirtBurners,SMAC Trac
X God is offline   Reply With Quote
Old 11-08-2008, 04:53 AM   #2
I would guess that it moves the motor weight closer to the center. Brushless motors are a lot heavier than a servo. Unless they are running something high RPM that they need the larger spur to get the ratio why not. It should help protect the gear from trash a little also.
plumslow is offline   Reply With Quote
Old 11-08-2008, 11:12 AM   #3
aeRayls's Avatar
ITs mostly because the motors they are running. To get the proper gearing pinion wise you need the smaller spur. I ran an lrp 7.5 with the sintered rotor geared between 24 and 26 to the 78. Certain motors/rotors have so much torque they need a lot of gear.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
SEO by vBSEO 3.5.0
