Exact size of novak's "oversized" bearing?
Had a bearing finally wear out in a 5.5 novak and have already replaced it with a new endbell kit. I have since removed the bearing out of the old endbell with the hope of replacing it for a backup. Anybody know the exact dimensions on the oversized endbell bearing?
http://www.rctech.net/forum/4973331-post6.html
If you check your original oversized bearing, you'll see R3Z marked (mine had) on the metal shield of the bearing.
