Old 10-22-2008, 02:39 AM   #1
RCRat's Avatar
Send a message via AIM to RCRat Send a message via Skype™ to RCRat
Default Cleaning a BL Motor...????
Is cleaning a BL motor required maintenance? If so how is it done properly?
I don't assume you just pop the backplate and spray away with motor spray.....
RCRat is offline   Reply With Quote
Old 10-22-2008, 03:08 AM   #2
UK.hardcore's Avatar
I take off the front cover with the rotor, and the plate that covers the rear bearing.
Take bearing out of cover and motorhouse.
then you must clean the bearing's as one would do like usual.
Check bearings for play and if it still runs as it should, if bad replace with new one.
the can along with the winding and sensor stuff inside you better not use motor spray, just air to blow out the dust.
Rotor's dont get messy to much, if it is i'd guess a paper towel is be best.
After that reassemble with caution not damaging anything and check for free rotating on the shaft.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 10-22-2008, 04:13 AM   #3
Drift_Buggy's Avatar
Trader Rating: 20 (100%+)
Have a read through this
Drift_Buggy is offline   Reply With Quote
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 06:38 PM
New Novak Brusless System danjoy25 Electric On-Road 2688 10-14-2010 08:40 AM
Brushless and Brushed stock equivalent... Are we getting it right ? Tpg racer Malaysian R/C Racers 31 11-20-2008 07:14 AM
brushless motors where are they at fasterdanu Australian Racing 434 06-13-2005 06:48 PM
SEO by vBSEO 3.5.0
