lrp on off switch >
lrp on off switch
lrp on off switch
Old 10-15-2008, 12:24 PM
ngl
ngl's Avatar
Default lrp on off switch
i have a t4 ready to run with the stock speed controll. the problem is, the wires got yanked out of the switch some how and now i don't know where to get a new one. it has to be just a plain off/on switch with 2 wires
thanks
ngl is offline
Old 10-15-2008, 12:50 PM
Trader Rating: 39 (100%+)
thanks
novak sells a switch that will work
Zac R is offline
Old 10-15-2008, 02:27 PM
trdsupra88's Avatar
Trader Rating: 25 (100%+)
If for some reason you cant find a switch, you connect the two wires together. This way works but when the battery is plugged in, the only way to shut the car off is to unplug the battery.
trdsupra88 is offline
Old 10-16-2008, 09:13 AM
ngl
ngl's Avatar
thank you
ngl is offline
Old 10-16-2008, 11:10 AM
rcmark24's Avatar
Trader Rating: 14 (100%+)
Just don't forget to unplug the battery pack when your done! Twisting the wires together is an easy fix when your in a bind but I suggest getting another switch. If you can't find the Novak I would go to Radio Shack and get a small on and off switch.
rcmark24 is offline
