Old 09-21-2003, 02:54 PM   #1
Default Adjustable Timing
What exactly does the adjustable timing change on motors and how does it effect performance.
igkyoa is offline   Reply With Quote
Old 09-22-2003, 10:42 AM   #2
sosidge's Avatar
more timing will increase performance at the expense of efficiency.
Most motors work at their best with timing between 12 and 18 degrees.
Old 09-22-2003, 12:51 PM   #3
TurnNBurn's Avatar
+Timing = More RPMs, Less Torque, higher Amp draw
-Timing = Less Rpms, More Torque, less AmpDraw.
When determing the best timing point, the objective is to have the best combination of those three components. Most motors usually are pre-adjusted at the factory (particularly the hand-wound Mods), so the best bet is usually to try and keep the factory settings. If you can't be exact, the range Sosidge suggested is a good guestimate .
TurnNBurn is offline   Reply With Quote
Adjustable Clutches air8 Nitro Off-Road 13 09-12-2008 05:31 PM
Tekin R1 Pro and adjustable timing Ferret Electric Off-Road 3 06-14-2008 02:31 AM
Difference b/tween ESC timing and timing on motor? Loverc Electric On-Road 8 04-11-2008 04:45 PM
adjustable timing on nosram brushless redlinezak Electric On-Road 0 03-10-2006 08:19 AM
X ray T1R adjustable shock perry maguire Electric On-Road 4 10-14-2003 01:16 PM
SEO by vBSEO 3.5.0
