Old 10-08-2008, 07:54 AM   #1
JAM MaxAmps's Avatar
Arrow Attention Traxxas Slash owners!!!!!
Maxamps now has an LVA "low voltage alarm" That can be made to fit into any balance tap plug you may have on your li-po's. Yes now you can run Li-po's in your Stock Slash. This LVD can be ordered with the balance tap connector you use. You then Plug this tiny unit into your pack and it will show a sequence of lights for different voltage stages. Then when your pack get's to the critical voltage point it will sound an alarm.
For more information about this great little device check it out here:
2S Version: http://www.maxamps.com/Doohan-2S-LVA.htm
3S Version: http://www.maxamps.com/Doohan-3S-LVA.htm
Simply choose the balance tap you use and we install it on the unit for you. Then you simply plug the device into your pack when you use it.
Note: Never leave the LVA plugged into your pack when not in use. Doing so may drain the battery beyond the LVC point. This is an alarm only not a cut off device.
Best regards,
www.NitroKillers.com www.MaxAmps.com Caster Driver
JAM MaxAmps is offline   Reply With Quote
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 08:24 AM
Traxxas Slash VXL for trade. Scranton,pa sublime30 R/C Items: For Sale/Trade 21 10-20-2008 04:39 PM
Traxxas Slash and Traxxas Jato 3.3 SerpentCT4S R/C Items: For Sale/Trade 9 08-13-2008 01:39 PM
Brushless setup for Traxxas Slash rapster402 Radio and Electronics 0 08-07-2008 04:53 AM
SEO by vBSEO 3.5.0
