novak motor plug
Old 10-02-2008, 06:19 AM
Default novak motor plug
hi the plug on my novak brushless motor melted and i need another one
is there anywhere i can get one as id rather not have to buy a new motor,
its the plug with 6 wires coming into it that plugs into the speedy
*ASSOCIATED* is offline
Old 10-02-2008, 06:36 AM
Briguy's Avatar
Trader Rating: 125 (100%+)
Novak sells them , http://www.shopatron.com/product/part_number=5356/135.0
You will have to cut one plug and solder the wires to the motor . If you are good at soldering it is no big deal .
Briguy is offline
Old 10-02-2008, 06:37 AM
No, you may be able to solder a section in to it , but to me its not worth
it for fear of frying your speedo next. You need to send it back to Novak I
think the replacment cost is $50 for a new motor.You also can buy a motor
with a replaceable sensor such as a speed passion motor.
Dynodan22
dynodan22 is offline
Old 10-02-2008, 07:57 AM
thanks for the link mate
im not to bad at soldering so ill give it a go,
and dynodan22 how would doing this risk my next speedy, if there all soldered good i cant see it being a problem?
Old 10-02-2008, 08:38 AM
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
You guys do know that you can pull the wires out of the connector, right? Just replace the melted part.
Just use a sharp hobby knife to lift the little tabs and the wires pop right out.
Turbo Joe is offline
