Cost Efficient Soldering Iron
Can anyone recommend a good but cheap soldering iron?
I don't want to build my own NiMH packs; I just want to solder only one wire on my Novak ESC, so that's why I don't need anything expensive.
I know Radio Shack sells soldering irons, but are these sufficient for my purpose?
Also, what additional things will I need other than solder?
Thanks for any info.
Thanks for the info.
As for what else I might need; I read something that talks about using a "braid" to remove the existing solder... what exactly is that? And is there anything else I will need for this minor soldering project?
The "braid" they are talking about is actually solder wick.Here is a link to what I use.http://www.sparkfun.com/commerce/pro...oducts_id=8775
Suspended
Radio shack, Sears, Ace Hardware and others sell irons that will easily suit your purpose and cost 20 bucks or less. As long as you get one that's at least 40watts you'll be fine. Do not use sandpaper to clean the tip, wipe it off on a wet sponge or paper towel --- it'll last longer.
That ones a piece of Shit i had it. The best one to get is the weller sp40l 40w
http://www.all2ools.com/index.pl/fro...ctid=WLR/SP40L
Have had this for over a year and it works well. That hobbico will ruin your cells the tip sucks.
R/C Tech Elite Member
Actually most of the "cheap" soldering irons imho are pos.
I have had 4 of the under $40 irons
If you really want one that works look for a good used Hakko on ebay or on here in the for sale page
I got a good (hardly used) Hakko 936 for $45 on ebay and it is amazing to say the least. You can do it all with that staion.
It may cost a lil more but you will be better off! I threw away all 4 of my "cheapo" irons! All 4 together would have bought a BRAND new 936.
Having a good, hot iron is essential for soldering work. At least 40W, and a chisel tip, forget those pointed tips, they don't hold the heat.
If you think it's a waste of money, I just f*cked my Tekin ESC by having a iron that wasn't hot enough, and melted part of my circuit board because I held it on the pole too long. THAT was a lot more than the cost of an iron, believe me
Home Depot has one under 20 bucks (Weller) and comes with a chisel tip. I see alot of racers using them.
Spend $80 on the Hakko. It's cost effective and efficient as you'll never buy another soldering iron again. ...and it's only $80.
I agree the little $8 Hobbico irons are pretty cheesy...but, they're $8. They come with 2 tips, and if you take decent care of them they'll get you through a ton of joints before they both erode away. Usually by that time the iron itself is so corroded from the heat the tip won't even come out. But I'm also reasonably satisfied in saying I got my 8 bucks worth out of it, toss the whole thing in the garbage and buy another one.
Now, if you're one of these guys that hardwires everything and is using a soldering iron nonstop, then I could see spending the money on a Hakko. But for a guy like me that has connectors on all his batteries and only pulls a motor out when it needs to be worked on, the little Hobbicos work just fine.
Just my $0.02
Just my $0.02
