Cost Efficient Soldering Iron
#17
Suspended
#19
Suspended
In the pitbox to go trackside, where I do little more than a wire or two from time to time, is a $18 40w Weller. If it dies or gets dropped or broken or borrowed and not returned no worries.
#20
That ones a piece of Shit i had it. The best one to get is the weller sp40l 40w
http://www.all2ools.com/index.pl/fro...ctid=WLR/SP40L
Have had this for over a year and it works well. That hobbico will ruin your cells the tip sucks.
#21
High-cost is all relative. Consider these:
http://www.techni-tool.com/static-pr...al_MX_500.html
Workhorses of many electronic assembly... Hakko 936 is considered "cheap" compared to these!
My own personal experience, a tool has to be able to do the job and do it well. It's not the cost of the tool that weighs in, it's the quality of the job and how much that is worth...
#22
Suspended
... and of course Tool Time's own Tim Taylor has his own point to be made.
#23
Suspended
#27
So I got a 40-watt soldering iron from Radio Shack, some desoldering braid, and .062 rosin-core solder.
Is this all I need? Is the .062 rosin-core solder the type of solder I need?
#29
Can anyone recommend a good but cheap soldering iron?
I don't want to build my own NiMH packs; I just want to solder only one wire on my Novak ESC, so that's why I don't need anything expensive.
I know Radio Shack sells soldering irons, but are these sufficient for my purpose?
Also, what additional things will I need other than solder?
Thanks for any info.
http://cgi.ebay.com/Stained-Glass-Su...QQcmdZViewItem
I had a ungar 40watter for everything else. The one in the Ebay auction really works great on motor plugs on brushless motors, I haven't had a cold joint since using it
#30
