Flat Tire
Flat Tire
I have a Jammin CRT.5 converted to brushless. The little truggy is fast, handles well and is one of my favorites. I normally run the stock wheels/Crime Figther combo. After a few weeks I noticed the tires felt a little flat, like there was no foam in the tire. So after the tires wore out I cut one bead and opened the tire up and the foam was in really bad shape. One reason to use good foams in your tires, the wheels/tires had about 5 or 6 days of hard racing/practice on them, and they started feeling soft after the 4th day.
Ya... if you are going to be using tires for several weeks.. good foams do help..
Looks like to me that those foams may have gotten wet from cleaning the tires and then dried out... that will break up the foam pretty fast..
Be careful not to dunk the tires in water if possible. There are holes in rims and usually the bead is not water tight.
Good luck!
Jerome
Good luck!
Jerome
Dunk a scrub brush in the water/soap mixture and scrub the tires.. then rinse them off.. don't dunk the tire in the water...
Holes in the rims will still allow water in.. the water and then slowly drying is what makes the foams shrink and fall apart faster.
If you must dunk them.. be quick about it and definitely don't squeeze them underwater.. that will just suck in more liquid!
Jerome
Jerome
Jerome
Jerome
they r still firm
the hole in the tire is so water can come out,like when u hit the gas the tires expand when water in the tire the water will come out i did this on every tire and i did it on one set that i didnt do it to and the foams where gone in 3 weeks the foam thats in the tire w/the holes
they r still firm
they r still firm
Holes are put in the rims to allow air to escape, not water. You should not be dunking your tires in water.
Suspended
don't you know he's a self-professed RC guru and master of the universe? LOL
I glue a brush to the bottom of plastic tub and fill the tub up to the tip of the brush . Then rub the tires on the brush and wipe them down with a towel all clean with no water inside the tires . Not only are you saving your foams when not dunking them but you also are putting your wheels out of balance when the foams get wet .
Your both right.. He is talking about puting a hole in the TIRE. I have seen alot of people do this to get the dirt that comes in the air hole in the Rim/wheel out. . So I see how it would also work in a way to let water out. Its funny how you Criticized his comment without reading and understanding, that hes talking about a hole in a different place than what you were. I don't think anyone should be dunking tires in water, but its a useful tip for the people with the waterproof cars out there...
Suspended
He was making reference to the first poster who obviously had allowed dirt to get inside his tires, regardless of how it got there, that wore away his foams. And the easiest way for that to happen, other than not gluing the tires on properly, is by having holes cut in the tires.
Why bother correcting or chastising him if you are wrong.
Check this out. If you drill a whole in the inside of your rim. (as I and most of us do) You get dirt in the inside of your tire.
If you put a second whole in the Tire, as I and alot of other racers have done. It trows alot of the dirt back out. Thats why I can agree with Mr Porkey about the water getting back out through the tire hole.
You must have miss this post to think he was not talking to Mr Porkey. Mr Porkey clearly describes placing the hole in the tire, and in Mr SQC049 statement he says
"Holes are put in the rims to allow air to escape, not water" clearly not talking about the same whole as Mr Porkey, but telling him he was giving bad advice.
they r still firm
SQC049 said...
It is funny how wrong you are, yet you give advice like you know what you are talking about.
