Old 09-13-2008, 06:39 AM   #1
butrflynlambie's Avatar
Default Tires : Molded Inserts?
I see sport werks has a molded insert for 1/8. I was wondering if the molded insert results in a better balanced wheel to start with.
Do they work or are the foams just as good?
butrflynlambie is offline   Reply With Quote
Old 09-13-2008, 06:46 AM   #2
Davidka's Avatar
Trader Rating: 72 (100%+)
Generally molded inserts don't help balance, cut standard foams are really light and consistent and molded foams are a little heavier but can last longer. The balance problems are usually because of the rubber.
Old 09-13-2008, 07:05 AM   #3
schmelme's Avatar
Cut ofna orange foams work great. They only fit the carcass of the losi tire tho. The proline tires are slightly larger and the fit is to loose.
Contact cement works best to glue the foam together it makes a flexible seam.
They work well i use them on the tracks we run pink slicks on.
schmelme is offline   Reply With Quote
NEW JConcepts molded 1/10th buggy tire insert ifuonlyknew Electric Off-Road 25 01-31-2016 01:00 PM
Hong Nor / Jammin Products And RC Fans Thread plazma Malaysian R/C Racers 1717 04-02-2013 01:07 AM
New 1/8th buggy tires wrightcs77 R/C Items: For Sale/Trade 12 03-13-2008 05:43 PM
It Doesn't Add Up !!!! WN4B3 Electric Off-Road 19 05-08-2006 05:50 PM
SEO by vBSEO 3.5.0
