T4 trailing steering block upgrade??
Ok so i went into my local hobby shop about a week and a helf ago,And was discussing racing and what not and i brought my t4 in to juts check everything out on it.Well he told me to upgrade the trailing blocks in front to ones off a traxxas stampede truck due to the stampede ones are twice as big is this possible??I was wondering is that even smart to do for racing and has anyone ever tried this swap out???Also what size tire would i need to run then??
Ok i was just wondering cause he said they would hold up better.And i wouldnt have to use the plastic nut on it.Said the plastic nut strips out and ill constantly lose them.I just now saw that i am missing a bearing in the front wheel and the tire has satyed on the whole time,not sure where that one went.
RC10T4 UPDATES
Most of these are to make the front end stronger
7914 GT2 Front Shock Tower
7917 GT2 Front A-arms
7921 GT2 Steering Arms
7919 GT2 Front Caster Blocks (25 Degree)
9730 B44 Rear Hub Carrier With
7935 3/16 x 1/2 Outer Bearings
7889 5/64 x 1/4 Bearing in place of Steering Rack Bushings
3858 Black Ball Ends on Steering Rack (link to steering arm(s))
VERY Low Traction try,
7932 GT2 Rear Hub Carrier (1.5 degree)
Well my front end itself is very strong i got full carbon,and my rpm wide bumper saves the front end most the time so.I was just told to upgrade,But im not gonna worry about it.I do gotta figure out where one of ther front wheel bearings went when i havent even taken the tire off is the front for awhile.
RC10T4 UPDATES
Thanks for any further information
idbdoug
I had them on my T4 when I was racing it with a Novak 4.5 in it!!!!
Yes OFF ROAD!!!
ALL the tracks are "VERY Low Traction" with a 4.5!!!
Worse when I had a 3.5 in it!!!
