Old 08-30-2008, 03:05 PM   #1
Trader Rating: 16 (94%+)
Default weight inside wheel
im just curious if anyone has tried putting weight on the inside of the wheel? would it give the car more grip?
BSS07 is offline   Reply With Quote
Old 08-30-2008, 03:38 PM   #2
JeromeK99's Avatar
I've put weight on the insides of wheels to balance them.. but never for "more grip".
Seems like there are much better things to do than to add to the rotating mass of the drive train.
There are an infinite amount of adjustments you can do to your suspension not to mention different tires and compounds.
The front tire grip can play a role in your rear grip as well... if your front grip is too great, the rear can break loose especially in the corners. Again, your front suspension can be adjusted as well.
Don't forget about adjustments to your slipper clutch and differentials.
You can change to different wings on a buggy and bodies on trucks. They are NOT all equal!
Adding weight to the wheels just sounds like a bad idea. In all sorts of racing, not just r/c, the idea is to go as light as you can for speed.
Just my opinion..
Have fun!
JeromeK99 is offline   Reply With Quote
Old 08-30-2008, 05:06 PM   #3
Trader Rating: 21 (100%+)
Wheels are not the place you want to be adding weight. Same effect in changing to a set of much heavier wheels - any traction gain is more than offset by loss in acceleration. Heavier wheels will also make your motor run hotter.
If you're having traction probs, look to suspension tuning, not adding weight to the wheels. Xray buggy manuals have a great suspension tuning guide, they tell you adjustment by adjustment what each one does and how it affects the vehicle.
Duster_360 is offline   Reply With Quote
Old 08-30-2008, 06:36 PM   #4
Unless its a rock crawler i would stay away from putting weights on your wheels unless its small amounts to balance them
Tater salad the stories behind nick names how it stuck at that track is beyond me, good times, short lived, forever missed FHR.
Tater salad is offline   Reply With Quote
Old 08-30-2008, 06:53 PM   #5
KARZ Calgary xrayroooahhhh Canadian R/C Scene 19062 10-20-2016 10:38 AM
Tamiya Direct Drive Touring Car Barry White Electric On-Road 1586 11-28-2012 10:03 AM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
Xray T1FK05 Mdoc Electric On-Road 5433 01-31-2010 05:42 AM
KYOSHO MP9!!!!!!!!!!!!! New Jack Nitro Off-Road 8 07-07-2008 04:39 PM
Pro-squat raptor 700 Electric On-Road 48 05-29-2006 09:59 PM
Rear end lifting on the inside Cole Trickle Electric On-Road 20 04-16-2004 04:08 PM
SEO by vBSEO 3.5.0
