1/8 8IGHT-E 4WD Buggy Race Roller
At a Glance
Losi's 1/8-scale 8IGHT-E 4WD Buggy Race Roller combines the innovative design and technology of Losi's award-winning 8IGHT Competition Buggy Chassis with the fierce torque and speed of Losi’s 1/8-scale Xcelorin Brushless Systems.
The 8IGHT-E Race Roller is a competition buggy chassis that has been hand assembled and tuned to exact specifications. Each and every screw is installed to specific torque settings to maintain consistent construction. Additionally, every screw or bolt that secures metal-to-metal contact features thread lock to prevent backing out or loosening due to vibration. The differentials and shocks are pre-built and filled with 100% pure silicone fluid.
The 8IGHT-E Race Roller features Losi’s superior 1/8-scale Xcelorin Sensorless Brushless Power System. The fully programmable, high-output electronic speed control (ESC) can handle a 3-5-cell LiPo battery pack, and offers precise throttle and braking control. The 2100Kv brushless motor requires virtually no maintenance, while offering unmatched efficiency and speed designed for 1/8-scale racing. Additionally, the ESC offers tons of programming options, including adjustable throttle limits, selectable user profiles, and much more using the Quick Programming Card or personal pc programming software.
Once assembled, the 8IGHT-E Race Roller is given a complete inspection to ensure that it meets Team Losi Racing’s requirements for durability and performance. You can be sure that your 8IGHT-E Race Roller is ready for serious competition as soon as you open the box.
Features
Pre-installed Xcelorin 1/8-scale Brushless System with 2100Kv Sensorless motor w/5mm shaft
Secure, hard-mount Xcelorin ESC with rubber shock absorbers
4mm motor mounting screws
Large ESC heat sink with fan to keep damaging heat away
Molded LiPo battery tray with hook and loop straps that can accommodate a 3S to 5S LiPo
Newly designed body specially built for the 8IGHT-E for improved air cooling of the electronics
Adjustable aluminum motor mount with rear motor support
4mm thick machined and hard anodized aluminum chassis plate
Unique narrow chassis configuration for quicker handling and ground clearance
Oversized shocks with threaded hard anodized shock bodies
Sealed front and rear differential housings keep dirt out of the gears
Zero bump steer design with adjustable Ackerman
Captured hinge pins require no retaining clips
Machined premium aluminum 5mm thick alloy shock towers
Product Specifications
Type:Electric Competition Buggy Race Roller
Scale:1/8
Length:19.5 inches (495mm)
Width:12.13 inches (308mm)
Wheelbase:12.64-12.80 inches (321-325mm)
Chassis:4mm Hard-Anodized Aluminum
Suspension:H-Arm, Full Independent
Drive Train:Offset Drive with 3 Sealed Differentials
Motor or Engine:1/8 Xcelorin Sensorless Brushless Motor, 2100Kv
Speed Control:1/8 Xcelorin Sensorless ESC
Radio:2-Channel Radio System (sold separately)
Servos:High-Torque (sold separately)
Batteries:3-5-Cell LiPo Battery Pack (sold separately)
Charger:Sold separately
Wheel Size:17mm Hex
Kit/RTR:Race Roller
Shock Type:Oversized Hard-Anodized, Threaded Bodies / 4mm Shafts
Body:Clear, 0.040-inch thick, Electric Buggy Racer Body
Ball Bearings:Complete
Needed to Complete
Compatible Battery Charger
2 Channel Radio System with High Torque Servos
Paint for Polycarbonate Body
Losi Recommends:
14.8V 5000mAh 4S 25C LiPo Hardcase Battery Pack (LOSB9864)
Intelligent LiPo Balance Charger, 1-5 Cells (LOSB9605)
Price: $879.99
Source:
Losi.com
