2wd vs 4wd rear diff tightness? >
Old 08-19-2008, 05:44 PM
Default 2wd vs 4wd rear diff tightness?
As a general rule of thumb, in a 4wd car, the front diff is tighter than the rear.
Is the tightness of the diff in a 2wd and a 4wd REAR diff tightness similar for a given track?
Would you say that for a given track, the 2wd diff is more similar in tightness to that of:
A. the front diff of a 4wd car or
B. the rear diff of a 4wd car?
Just curious...
Thanks!
haulin79 is offline
Old 08-19-2008, 05:48 PM
Briguy's Avatar
Trader Rating: 125 (100%+)
You don`t want the diff to slip in a 2wd buggy .
Briguy is offline
Old 08-19-2008, 11:28 PM
Brandon A's Avatar
I've always run the diff on my 2wd tightened almost all the way down and it's always worked really well, at least for my driving style. I have a one-way in the front of my 4wd so that doesn't make for the best comparison.
Brandon A is offline
Old 08-19-2008, 11:44 PM
I would say (b) similar to the rear unless you run your rear diff on your 4wd to the point where it slips a little. You just dont want it to slip like stated above.
Tater salad is offline
Old 08-20-2008, 01:26 AM
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
I have always bult the front and rear exactly the same, and I have never had a diff issue.
Tighten all the way 1/8 turn back.
Just my .02
OG RC 10T is offline
Old 08-20-2008, 07:09 PM
nitrotruckn's Avatar
Just my .02
....works for me as well
nitrotruckn is offline
Old 08-20-2008, 08:20 PM
Aaron P's Avatar
In 2WD, run the diff as loose as possible, but without any slipping. A tighter diff takes a bit of steering away, looser lets the car rotate easier.
Aaron P is offline
Old 08-20-2008, 11:22 PM
