rc10t4 13.5 gearing
Making the switch from on-road to off-road because there is a track much closer. I'm going to run my 13.5 in my t4 just to get used to the switch. What gearing should I run on a 1/8 scale hard packed clay track? Thanks for the help.
i was running 87/24 in my truck, but it could be geared higher with a smaller spur
Originally Posted by Jake S
(Post 4758602)
Anyone else run something similar...or a little different? |
I run a 78/27 with trakpower 4900mah lipo, GTB esc and a Orion 13.5. With a novak I run a 78/28.
Originally Posted by Stallard
(Post 4759439)
Gear
I would run a 78 spur and play with pinion size until you find what you need.Just keep a check on motor and esc temps.
Thanks:nod:
