R/C Tech Forums (http://www.rctech.net/forum/)
-   Electric Off-Road (http://www.rctech.net/forum/electric-off-road-4/)
-   -   380, 540, 550, 720 motor sizes? (http://www.rctech.net/forum/electric-off-road/238188-380-540-550-720-motor-sizes.html)
haulin79 08-20-2008 11:10 AM
Do you know the dimensions of these motor sizes or if there is an official chart of motor sizes?
For example, how do motor manufacturers know how to designate their motor sizes?
540, 550, 720
kufman 08-20-2008 02:58 PM
Those numbers used to roughly indicate the length of the can. a 540 was about 5.4 cm long.
yzracer758 08-20-2008 03:07 PM
Not sure if this is what you are looking for but Tekin for instance has motors labeled as 358 or 448 and so forth.
358= 5800KV
448= 4800KV
Hope that helps any.
Cornelius 08-21-2008 01:36 AM
Those numbers refer to the motor diameter.
540 has a diameter of 36mm.
380 has a diameter ~28mm.
280 has a diameter of 24mm.
The S, L or XL after the numbers refers to the motor length.
With some searching you may be able to find a chart online that lists other motor sizes.
GT-R35 03-13-2009 10:08 PM
E10 Drift?
E1:tire: drift with EN-1, is it possible to put a Titan 55:tire: 12t (8.4v all the rest of the specs are in the numbers)?
gweed 03-13-2009 11:21 PM
? why would you want to put a titan 550 in anything. that motor is garbage.
ta_man 03-14-2009 08:20 AM
Spoken as a true Traxxas hater. It is not garbage, just something you don't like.
gweed 03-14-2009 09:38 AM
No that motor is junk. its pointless in anything except a slash spec class which you're gonna see evolve it to corr truck so that motor is gonna be pointless
kufman 03-14-2009 10:09 AM
Anything with bushings and non-serviceable brushes is pretty much junk in this day and age. Heck, anything with brushes is pretty much junk. IMHO.
123quattro 03-16-2009 07:27 AM
I own a Slash, and will be the first to say the Titan motor is junk. That was the first thing to fail on my truck.
ta_man 03-16-2009 02:29 PM
And yet we've got 30+ people racing at out club since the truck came out and maybe 3 or 4 motors have died in 9 months.
People sometimes fail to realize that one data point doesn't make a trend. That one data point (yours) doesn't mean all the Titan 12T motors are junk, or for that matter, even that the one you destroyed was junk. People come on these forums to complain. The 26 guys at my track that haven't had any problems overwhelm the 3 or 4 that did, but they think it is normal for the motors to last and last so they don't bother posting about them.
It really depends more on how you treat them than anything else. Some guys just destroy stuff no matter what you give them because of the way they treat their equipment.
navyeoseabee 08-14-2011 08:11 PM
30 people over 9 months, and 3-4 motors went bad....BBBBSSSS! if they were racing they were using that motor 3-6 times and swpping before that junker went BAD!!
in fact i bet they were running a stock class at your club...stating that they can only run the junk titan to be elgible for that class. :nod:
rc_in_mexico 08-14-2011 09:53 PM
I wouldn't say closed end bell motors are junk. They just arent up to par with brushless motors. I am using a midnight pumpkin with a 25+ years silver can motor and it's pretty good. Ive had good experience with the Titan motors as well. Some people get a bad motor and some just kill them. I'm sure there are a few bad brushless motors once in a while too
Drbrake 12-29-2014 06:54 AM
Thanks for the info. just what I was looking for.
I assume a 550 has the same diameter as a 540??
RC*PHREAK 12-29-2014 08:38 AM
correct
Content © 2001-2011 RCTech.net
