HELP!! losi problems.
hey got a prob with me xxx-t cr. i am trying to put the pin in the hex on the back wheels. but the pin will just not go thought the hole any ideas??
pauly you struggle putting pins in holes hay!:lol::lol::ha::lol:
Are you sure you have the correct pins ? Losi has like three different pins .
tap, tap, tap it in...
Originally Posted by MattWebb
(Post 4747070)
they are the pins that came with the kit truck. if i dont put the hex on the pin fits but if i do it does not??
Originally Posted by peaksystem
(Post 4747165)
tryed it it just will not move. might get drill out hahah jokes. yer i hit is pushed it. tryed to but a key though it and it fit so it might be the pins but the ones in the cbd fit great
You are using the smaller hollow pins , right ?
nar no hollow pins in the bag that is came with. i tryed changen the pin around from the cvd the cvd ones are smaller and fit flush and the bigger pin i am useing for the hex but yer just will not line up
The pins are a royal PITA to get in. Make sure it fits into the hex nut by itself and then make sure it fits into the hub. If it fits in both then your probably just having difficulty aligning the holes. Try using a small dental probe or similar device to line up the hole than tap the pin in.
You can also use a toothpick to line them up . Most of the time
I use a strong light so I can see when I have them all lined up start it in . Then take a pair needle nose pliars and squeezethe rest the way in . Dynodan22 Oh yea make sure you have the quick release in the right way and push the shaft to the outside it has a tendency to float back in when you try to go to align the pin. |
Originally Posted by Briguy
(Post 4747092)
tap , tap taparoo
Originally Posted by Drift_Buggy
(Post 4749890)
Time to go home there Pin
MattWebb said tap , tap , tap it in . I followed with tap, tap, taproo . Which is a saying from Happy Gilmore . |
