Old 08-11-2008, 04:33 PM   #1
Default Brushed Motor Timing, how do you know how far?
Brushed Motor Timing, how do you know how far to go?
Do you just keep in increasing the timing until the temperature hits a target?
If so, how hot should a brushed motor get?
haulin79 is offline   Reply With Quote
Old 08-11-2008, 05:13 PM   #2
T. Thomas's Avatar
Electric motor timing basics for brushed motors:
More timing ( 15* - 35*) = more HP and better RPM but this will also wear out the brushes faster and reduce the lower RPM torque
Less timing (5*- 15*) = More toque and accelerate quicker from stop but will cost a little top speed and the brushes will last longer compared to more timing.
When using the same motor and only changing the timing it will affect the acceleration drastically in certain circumstances. This will ussually require a gear change, ussually 1 tooth smaller spur for less timing and ussually 1 tooth less on the pinion for more timing. In offroad truck I always prefered to run 10-15 degrees, buggy I liked 15-20 degrees, and when I did run 4wd it was 5 -10 degreed of timing, for this allowed the brushes to last a lot longer. You do not need to concern yourself with trying to adjust timing for the motor to reach a certain temp, you use this to help adjust how the motor performs(you want more rpm or more accel. No matter what I always tried to keep my motors as cool as possible no matter what.
T. Thomas is offline   Reply With Quote
Difference b/tween ESC timing and timing on motor? Loverc Electric On-Road 8 04-11-2008 04:45 PM
Motor timing help. wade7575 Electric Off-Road 1 02-21-2008 02:23 PM
19T Brushed Motor Maintenance Lot! Lathe, motor, spring thing, etc! Cain R/C Items: For Sale/Trade 0 09-11-2007 06:08 PM
Brushed motor clean out - XIPP LATHE / PEAK VANTAGE MOTOR RUN---ChEaP--- wannabee R/C Items: For Sale/Trade 10 03-10-2007 05:30 PM
Motor Timing RocketRacer Electric On-Road 6 06-22-2006 12:11 AM
SEO by vBSEO 3.5.0
