what motor to put in a evader st??
im looking for somthing that is 17 turn
and good for backyard bashing ect any ideas? thanks PC |
The Orion “Rush” series sounds like what you’re looking for. They’re dirt cheap and have bearings: https://www.ssl-stormerhobbies.com/c...pl?pn=ORN25103
well you beat me to it i was about to update this
i bought a trinity speed gem 2 saphire 17x1 partly becuze my LHS had one i was looking at the speed gem 2 17x2 (think its the amethyst) thanks though Proud Canadian |
Im in to nitro rc and am looking to get into electric as well but i know enought to give you some suggestions. go to each of these sights and decide for yourself what looks best:
TEAM ORION http://www2.towerhobbies.com/cgi-bin...?&I=LXFBF7&P=0 http://www2.towerhobbies.com/cgi-bin...?&I=LXFBF0&P=0 http://www2.towerhobbies.com/cgi-bin...?&I=LXBGD3&P=0 -(has adjustable timing) http://www2.towerhobbies.com/cgi-bin...?&I=LXCYR2&P=0 PEAK PERFORMANCE http://www2.towerhobbies.com/cgi-bin...?&I=LXBHF2&P=0 TRINITY http://www2.towerhobbies.com/cgi-bin...?&I=LXJT00&P=0 ---These Motors are Designed to Meet the Power Needs of Touring Cars and Backyard Basher Who Want Good Performance Without the Higher Cost of a Hand Wound Motor.-- http://www2.towerhobbies.com/cgi-bin...?&I=LXJX14&P=0 If i were you i'd get a motor with lower turns (lower turns MORE power). Maybe get one with 12 or 14 turns - that will really get it moving, however if your using the stock speed contol im sure you would have to replace it, since it would probably blow, anyway i hope this helps you, all the motors i picked out seem alright, but i would go with TRINITY, they seemed to be the best out of them all. |
Before dropping your money on a low turn motor check to see if your ESC can handle the load. Usually an RTR electric's ESC can go down to a 15 turn but may burn up if used with a low turn motor.
