Old 02-02-2009, 12:23 PM   #136
gweed's Avatar
Originally Posted by SQC049 View Post
Make sure you don't have front truck shocks on the rear of your B4. Also, makes sure you have the right shock shafts in the front of your 4 wheel.
kyoslo RB5/ novak motors/ LRP sphere/ m11/ orion 4800,3800,3600/ blazin chronic racing/wphukuall radio/ raikkonen body/ mongoosed km-mini inferno with the multiplex red ass servo that owns johnny b-main and drew/ now at lir the JDM zx-5 sp mugen edition
"team bad guys"
gweed is offline   Reply With Quote
Old 02-02-2009, 12:26 PM   #137
Originally Posted by ultegrasti View Post
all else fails, call tommy vu
RobbieT is offline   Reply With Quote
Old 02-02-2009, 08:57 PM   #138
use a paint brush for cleaning off dirt. get the chunks off and then put some silicone shock oil on the brush. it softens the rest of the dirt and makes the plastic parts and tires shiney, lightly lubes the cvd's, hinge pins, ball cups... I wipe off the brushed on oil with a towel. it works great and it doesn't rust your hardware. Every once in a while I get shock oil in a kit that isn't labeled andd this is what I do with it.
make sure the holes in your rims are working and large enough. most rims aren't bad, but sometimes you get a plugged hole and it will mess up the handling.
pick upgrades that are actually upgrades. aluminum is heavy, graphite/composite parts are often more brittle. stock plastic in most cases (off-road)is your best friend.
when using brushed motors, give the brush leads a little tug before each race. it helps to keep them moving freely and greatly reduces the dreaded hung brush.
glue flat rubber washers(hardware store) on the tops of your body posts, it will prevent the posts from scratching threw your paint.
Get steel toed boots and a green mohawk. It won't make you faster, but fewer people will yell at you when your marshalling.
Current active RC's; Brushless Xray XB8, CRC Pro10, Tamiya M03, Xray M18, Losi Micro-T. Inactive list; Losi XXX-S, Duratrax Evader st, Traxxas TRX-1, Traxxas E-maxx, Brushless Ofna 9.5, Corally sp12m
Crazy_jay is offline   Reply With Quote
Old 02-04-2009, 05:16 PM   #139
hahaha the steel toe boots and green mohawk was hilarious...
B4 Racer1 is offline   Reply With Quote
Old 02-05-2009, 10:42 AM   #140
Trader Rating: 20 (100%+)
I thought servo saver is supposed to be loose to "save" your servo?
Being a newbie, I'm going to ask this question, how tight do you guys run your servo saver?
Originally Posted by B4 Racer1 View Post
make sure that your servo saver is tight...
"Slow is fast." I drove slow but why am I still slow?
javacrazy is offline   Reply With Quote
Speed Secrets (SS) RedEnzo Malaysian R/C Racers 197 09-21-2013 05:23 AM
Off-Road Tuning Secrets haulin79 Electric Off-Road 13 06-27-2008 08:30 PM
speed secrets?! any thoughts? streetracer745 Electric Off-Road 21 05-29-2007 10:51 AM
Racing Secrets!! Steve Charles Electric On-Road 68 11-22-2003 08:47 AM
SEO by vBSEO 3.5.0
