XXX-T! 1.5!
Suspended
XXX-T! 1.5!
Does any body have pics of a gtb in the truck so i can get an idea how to place!
Thank you!
Thank you!
I mounted my XBR on the drivers side of chassis toward the rear. Ran the wires to brushless between shock and shock tower for quick change (if I needed to pull ESC and motor) with tie strap to tower.
losidriver70 - What's up? Here is a picture of how I mounted my GTB in my XXXT CR.
Later.
Later.
Suspended
MIP/THORP! AE..............is the killer of All! Legend!
Whada up RobertjDrew, thanx for posting is the fan necessary in truck just asking? Do you run @ UnionCity!
losidriver70 - No problem. I haven't done much experimenting not running the fan. I think it's a good idea though to make sure everything stays cool. No, I don't I do most my club racing at Pegasus Hobbies and at OCRC. I used to race at Hot Rod Hobbies a lot.
Later.
Later.
Suspended
Losi!
Hey RobertjDrew, i've been out of truck for awhile can u send me a fairly decnt set-up i run @ CapCityrcCenter here in Sacramento i used to have the truck dialed just looking for a good starting point again! [email protected]
Thank You!Brian Mincks!
losidriver70 - What's up? I just sent you an email with a setup to try. Let me know how it works. I hope this helps you out.
Later.
Later.
Suspended
losi!
Thank you! L8...
