Please Confirm my order of Traxxas XL-5 . I need to buy
EDITED: i HAVE PLACED THIS ORDER AND I WANT YOU GUYS TO HELP ME ON TECHNICAL ISSUES. PLEASE READ POSTS AND YOU ARE WELCOME TO PARTICIPATE IN THE DISCUSSION.
Hi Guys,
I am going to buy a Traxxas Rustler XL-5 from AMAINHOBBIES. I need all the accessories which are needed to make this XL-5 RTR. I made this order which Chris_RC suggested me according to my budget. I am very very thankful to him. I need a final review from all of you guys. I need you to please tell me is there anything else I need in order to make the vehicle ready to run on arrival of shipment.
PS: I will buy the 8AA batteries from supermarket nearby so I have not included them.
Truck:
http://www.amainhobbies.com/product_...ducts_id/16232
adapter: (Please be dead sure is this the correct Adapter with the battery and charger and Rustler XL-5?)
http://www.amainhobbies.com/product_...ducts_id/17489
Charger:
http://www.amainhobbies.com/product_...ducts_id/13174
Battery: (Is this XL-5 capable of handeling 8.4 volt?)
http://www.amainhobbies.com/product_...ducts_id/18687
Please guyz tell me is this the correct order as I am newbie and please tell me all the accessories including battery and charger are compatable with each other and also with the Traxxas Rustler XL-5? Do I need to buy anything extra other than these for this Truck to be RTR on arrival.
Please reply as soon as possible so I can place my order Tonight.
Hi Guys,
Truck:
Charger:
This combo will work. If you use the seven cell battery, it will discharge faster than six and thus you will have less run time. Also, it will be very hot and you will need to wait until it cools naturally (no fan or ice) to charge again. Seven cell will also be harder on the drive train in the truck. Traxxas has a plastic motor mount and high heat in motor can distort the plastic. Are you getting more than one battery?
My personal preference would be to get a couple of six cell NIMHs and alternate them more run time, less stress, and more fun. But that is just me.
Thanx for the reply. One thing is confusing me. I am ordering this adapter:
But on the Rustler XL-5 page at amainhobbies they say:
Note: This kit uses the new Traxxas High Current Connectors to connect the batteries to the electronic speed control. So if your batteries have the old style molex connector, you will need an adapter TRA3062, or to replace the connector on your battery with TRA3080 connector.
and TRA3062 is this adapter:
http://www.amainhobbies.com/product_...ducts_id/17490
ow which should I buy with the accessories I am ordering?
This one:
Or this one which ther are talking about:
Please tell me which one should I order and can u please also tell me what would be the running time with the battery which I use.
This one:
get the 1st adpater. Traxxas male to Tamiya female. It is for the charger. The charger comes with Tamiya Male.
Thanx a lot for the reply. Can u please tell me the estimated running time of Rustler with this battery?
and what is the charging time? Complete battery charge time?
battery run time will be about 20-25 minutes. It depends how many amps you charge it at. I would charge it at .5 amps for the 1st run, 1 for the 2nd, and 2 for the 3rd while going slow to break in the pack. Normally I would charge that pack at 4 amps.
Why cant I charge the battery at 4 amps straight? Is there any performance matter? Please reply
yes, it is just good to "break in" the battery and truck. Just go slow. It is only 3 runs and you will have better performance later.
So do u mean to say, When I ll have the shipment, I will first charge the battery at 0.5 amps, and when the battery is finish and need to recharge I will charge it at 2amps and so on?
Run the pack
Then when it cools down charge it at 1A until its charged up
Run it
When it cools down charge at 2A, and so on up until 4A.
and the most important thing. DO i have to charge the first 5 times back to back or can I take interval say 2 times the first day and three times the next day?
Didnt get your point. Not sure u r answering of which part?
I have asked these:
1) I have to charge it 5 times on the above mentioned AMPS by you. But after the completion of this charging process. Can I charge it at 4 AMPS the next time and every time?
2) DO i have to charge the first 5 times back to back or can I take interval say 2 times the first day and three times the next day?
I have asked these:
1, yes, but sometimes just do a slow charge at say 1 amp or lower and trickle charge it for a bit to equalize the cells. The higher amp rate, the shorter it lasts.
2, DONT do them all in 1 day. If you do run down a pack, you should wait 3 hours before you recharge it. So dont do it in 1 day. I would do 1 a day for 5 days or something like that.
1)What do u mean by equalizing cells? Suppose I completed the charging process in 5 days and now I charge the vehicle for 4amps straight. Say after one day I again charge it for 4amps and then next day I charge it on slow 1 or less amps. Did u mean this?
2) As u said "The higher amp rate, the shorter it lasts" does this means the life of battery becomes shorter or the running time?
3) On a side note I forgot to ask. Does the remote control comes with the rustler which I have purchased or I have to buy it?
