Old 06-25-2008, 08:46 AM   #1
hrnts69's Avatar
Default Brushed Motor Tuning Tips
Hello, iam curious about brushed motor tuning tips. Mainly for Oval (Dirt,Carpet) and Carpet Touring Cars, Ive read the RC Motor Black Book on Hobbytalk already: http://www.hobbytalk.com/bbs1/showthread.php?t=126994.
Since that is kinda old, iam wondering if there are any newer articles that i can read up on tuning brushed motors. Or any tips or tricks to tuning these motors. Iam working on getting a comm lathe and dyno soon, hince why i am asking these questions.
Hobby Sport Media
hrnts69 is offline   Reply With Quote
Old 06-25-2008, 10:30 AM   #2
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
For starters, when you buy a comm lathe, get a regular carbide tool. Diamond tools might sound like a great idea but they're insanely expensive and (ironically) very fragile. Plus, when a carbide tool wears out it leaves a crappy cut. For some reason worn or cracked diamonds still leave a smooth finish on what is really a lousy cut. You can get carbide tools from McMaster-Carr for about $4, and some of mine have a lot of mileage on them. I bought four or five carbide tools about 4 years ago and I've only recently gone through the second one.
Unless you're going to use the new Reedy Stockstar or Challenger motors, you'll want to get something to align the brush hoods too. Some companies make these H-bar things that just sit on top of the endbell, but when you think about how they work you realize they're useless. All they do is align the brush hoods to each other, what you really need is a tool to align the brush hoods to each other and to the center of the armature shaft. I think Trinity makes a tool that's just a brush shaped bar and a dummy armature shaft: you build the motor with no armature or brushes, loosen the hoods and slide the bar through them, run the shaft through each bushing/bearing and the hole in the bar, and retighten the hoods.
Shimming the armature is important too, usually the factory job is kinda sucky. Pull the motor apart and remove all the factory shims except the phenolic (sp? I say it all the time but dunno how to spell it ) washer, the one right above the commutator. Put the motor back together except for the brushes, and spin the armature by twirling the output end of the shaft. Make sure it spins freely after you let go, the idea is you're trying to get the armature centered in the permanent magnets' field. When it stops, gently push on the endbell end of the armature and see how much it moves, then take the motor back apart and add shims to the output end. Keep messing with it until you've removed as much slop as possible, then do the endbell end. When you're done, the armature should just barely be able to slide up and down in the can. The closer you can get to zero movement without actually getting there, the better.
Breaking the motor in is very important as well, but there are MANY different ways of doing that, and the best method really depends on what you have available to you.
Dynos...I've never used one. All you get out of those is a bunch of numbers, and I've seen some motors that did well on the dyno run like garbage out on the track, or go like hell then blow up. When I do motor tuning I always start with two identical brand new motors, go through them both, drive them both, and pick a winner to go racing with. The other one serves as backup and I'll continue to experiment with it until the primary motor starts to wear out. From there on out I just keep going back and forth. I make my motors compete with each other to see what works and what doesn't
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 06-25-2008, 12:19 PM   #3
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
The RC motor black book is still relevant, and I still use the those tips. The poor man's way to check brush alignment is to use a sharpie to mark the face of your new brushes. After run-in check them to make sure the mark is worn evenly. If not, adjust the brush hood, re-mark and try again. Brush alignment is critical, and most 'pro' version motors have had this done already but I've had many motors come from the factory poorly aligned.
I agree with OTE on the shims also, there should be only a noticeable tick of endplay and the armature should always be held centered in the magnetic field.
Keeping the motor clean is probably the simplest and best tuning option you have as a beginner. At a bare minimum clean the motor at least once each race day or every 4-5 runs. It's truly amazing how much power a little crud in the bearings will rob you of. Bushings wear out much faster too if not cleaned religiously.
I finally bought a dyno, and while handy it really doesn't predict on-track perfomance. It can be helpful though if you dyno a motor that's running great, and record those settings. Then you have a point to tune that specific motor to the next time to keep it consistent. Watch amp draw as well as rpm's.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 09-30-2008, 09:46 PM   #4
thread revived
I just bought one of the new Reedy Challenger 19T.
I hear it has some advantages over the traditional 19 turns, so I wonder if there's a particular break in method for this one.
Rufus2000 is offline   Reply With Quote
Brushed Motor Tuning Tips hrnts69 Electric On-Road 1 06-26-2008 11:38 AM
Tuning tips for O.S. VZ-B??? jbish4 Nitro Off-Road 1 10-17-2007 09:02 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 10:04 PM
Tuning Tips. sl4ppinb4ss3r Electric On-Road 21 07-13-2006 03:35 PM
mp 777 sp 2? looking for any tuning tips gabbyb3 Electric Off-Road 2 03-05-2006 05:10 PM
SEO by vBSEO 3.5.0
