Help with power supply >
Old 06-23-2008, 01:40 AM
Default Help with power supply
What kind of min. power supply stats do I need to look for to power two Duramax Ice chargers both charging 6000 mah maxamp 2s lipo batteries at the same time? I'm not mistaken that these can both be run off the same power supply am I? Also, can these chargers be run straight off a car battery or deep cycle marine battery without a power supply? Sorry for the noob ?'s.
Any help is appreciated!
tekcor1 is offline
Old 06-23-2008, 04:35 AM
Will this work?
tekcor1 is offline
Old 06-23-2008, 05:51 AM
badassrevo's Avatar
yes that will work.
badassrevo is offline
Old 06-23-2008, 07:54 AM
RBMike's Avatar
http://www.radioshack.com/product/in...entPage=search
RBMike is offline
Old 06-23-2008, 10:23 AM
AcadDude's Avatar
Trader Rating: 19 (100%+)
Look at what charge rate you need. A 6000 mah charged at 1c is 6amps. Two of those at the same time although with two seperate chargers would be a total of 12 amps. You would need a power supply that gives you at least 12 amps. The one you listed at 20 amps would give you enough power for what you described.
AcadDude is offline
Old 06-23-2008, 10:28 AM
Makes sense. Thanks for the lesson!
tekcor1 is offline
Old 06-23-2008, 07:38 PM
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
i use the LRP 14 amp, very compact and works like a charm
http://www.BulldawgRC.com
Bulldawg RC is offline
