Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-10-2009, 05:40 PM   #286
Nehpets's Avatar
Trader Rating: 19 (100%+)
I took my truck out in the street just to give it a test run.
With a 5.5 geared at 18/78 it got to about 170 °F in under 3 mins . So I tried it geared at 16/81 and it was about 155 °F in about 5 mins. That was just criusing around in the street though, so I'd hate to see it on a track.
I didn't realise that I could get an 81 on there, but it still isnt enough. Any ideas? I tried an 84 and it was rubbing on the outdrives.
Maitland Off/On Road Radio Car Club - http://www.morcc.com/
X-6 - DEX410 - X-60 - Cyclone 12 - Cyclone TC - MRX4X
Nehpets is offline   Reply With Quote
Old 01-10-2009, 09:15 PM   #287
SpeedyDad's Avatar
If you can't gear higher than that, there is something wrong. Were you test runs high-speed runs? If so, that will make for a hotter motor as you don't generally run at full very often on the track. Paul and Jeremy hsve run theirs geared higher than that with mod motors.
X Factory X-60 - Keep on Truckin'
X Factory - www.xfactoryrc.com
BC1 Graphics
SpeedyDad is offline   Reply With Quote
Old 01-10-2009, 09:16 PM   #288
PHIL700XCSP's Avatar
Try a 16/78 that should put you really close.
PHIL700XCSP is offline   Reply With Quote
Old 01-10-2009, 09:43 PM   #289
gone banana's Avatar
it was my best night of racing with my x-60 TQ won 3 heats in the the main
we inverted the field 2 min in got to first lost it lap traffic finish 2nd
it alot like cheating
gone banana`z racing banana`z skin`z for all your foam tires need
2wdrc x-60 x-6 novak gtb, smc lipo
Cheese City Xtreme RC
FULLCOLORASSAULT body wraps
gone banana is offline   Reply With Quote
Old 01-11-2009, 05:01 PM   #290
Nehpets's Avatar
Thanks for the reply.
Test runs were just driving around on the street with only one or two highspeed runs.
When I say I can't gear lower it's because anything bigger than an 81t spur rubs on the outdrives, and anything smaller than a 16t pinion and the mesh will be too loose as I can't push the motor back any further.
I tried a 6.5 at the track yesterday with 16/81 and it was ok, still got pretty hot after 5 mins (Didn't temp it but I couldn't hold my finger on it for more that 4 to 5 seconds.)
I don't know how you guys aren't cooking motors running 5.5's at 84/21 and 6.5's at 78/21.
BTW, The truck was awesome at the track. Felt unreal compared to the T4, even with a poor choice of tyre.
Old 01-11-2009, 05:18 PM   #291
SpeedyDad's Avatar
Paul is running 21/78 with his 6.5. Brian and Alex have both run right about that equivalent too. With a 5.5 you'w probably be down to a 19t pinion but not down to 16t. It could be that you are geared too low. If you are geared too low, the motor is over revving and that will heat a motor up also. Try Paul's gearing. If you are still overheating there is something wrong somewhere else. What motor/esc/battery combo are you running?
Also, the on-street test is not as good as you'd think. Asphalt is pretty high bite so the motor will heat up quicker.
BC1 Graphics
Old 01-11-2009, 06:12 PM   #292
make everything spin free check the cvd bearing make sure the wheels are not rubbing the carrier my son running 5.5 novak in and geared 19/81 and come
at 90 degree that after 7 min heats
Old 01-11-2009, 06:27 PM   #293
Nehpets's Avatar
I see, I'll head up to the track again this week and do some more testing, I think I know where you're coming from with the gearing too low.
I'm running a Speedpassion GT ESC with an LRP X-11 and Trakpower 3600mah lipos.
Originally Posted by gone banana View Post
make everything spin free check the cvd bearing make sure the wheels are not rubbing the carrier my running 5.5 novak in and geared 19/81 and come
I think I got most of that . I pretty sure everything is spining freely. Doesn't hurt to double check though.
Thanks for your help guys.
Old 01-11-2009, 07:47 PM   #294
Trader Rating: 26 (100%+)
Send a message via AIM to Zac R Send a message via MSN to Zac R
81/21 with a 5.5 i though i had a 84.....
Kyosho America - Team Orion - AKA - B-Fast R/C - Dirtheaven Hobby & Raceway - CPR Racing Products - T.F.R - SpeedLine Designs - RMS Graphix - LiveRC.com - RC Scoring Pro
Zac R is offline   Reply With Quote
Old 01-13-2009, 03:13 AM   #295
bump to the top
Old 01-14-2009, 10:08 AM   #296
Khador12's Avatar
Say you are just getting back into racing and would like to race one of these. Has anyone put a list of the AE parts needed to build it? I was also wondering if anyone has tried Hotbodies shocks on one?
Khador12 is offline   Reply With Quote
Old 01-14-2009, 12:02 PM   #297
i think brian kinwald running Kyosho shock on his x-60 not for sure
to prices the stuff need to finish a x-60 x-factory would have everything you
to finish a kit
you should be able to pick a t4 for around 70.00
thing needed
t4 or b4 top shaft
Idler Gear
complete diff.
t4 front shock tower
t4 front bulk head
t4 front arms
t4 carrier 30 degree
i suppose any truck shock would work i like the t4 shock on my i`m running
30# oil all around with silver sping frt. black spring in the rear and it is dailed
after i come back from crcrc race in ohio i`m going to try losi rear carries front to to see if i can run losi quick change rims on it
Old 01-14-2009, 05:17 PM   #298
Nehpets's Avatar
I took the truck for a run yeterday arvo with the gearing at 21/78, After about 5 mins it was right on 200 °F. I let it cool down and tried 21/81 then fried the motor. (it was an oldish one that I am replacing anyway)
Are you guys running motor heatsink/fans? I'm not, how much do they help?
Old 01-14-2009, 05:30 PM   #299
SpeedyDad's Avatar
The older motor was probably the reason it was overheating. It was probably going bad to begin with. Like I said, others have run that gearing with no problems.
Alex does run fans but only because he runs 17.5 at bigger events and gearing is everything with that motor. To get better gearing, we needed to keep the motor cooler. We run 2 25mm fans on a custom mount.
We have not needed them on any other motor. I don't run them on my 17.5 equipped X-60 but I'm not as fast as him. He does not really need them on the faster motors but they are there already so...
BC1 Graphics
Old 01-16-2009, 07:22 PM   #300
day two at the crcrc it really nice to pit with the x- factory guy chazz and paul s. ,chris c. and the one brian kinwald
the x-60 is working good and x-6 feels good
in my x-60 i changed oil my shock oil to 27.5 all 4 shock it feel great. front spring are silver back black spring
thank you paul s.
Forum Jump
Heng Long Mad Truck (China) 1/10 EP Monster Truck??!! ALCW Malaysian R/C Racers 17 10-01-2009 03:53 AM
RPM 'Clawz' Stadium Truck Wheels & Truck Tires mrbrnz Australia For Sale/Trade 0 10-30-2007 01:25 AM
NIP Novak GTX/Spintec/Integy Tire Truer w/3-16" truck arbor/NIP TRC Truck Foams ridgewaybodies R/C Items: For Sale/Trade 24 04-29-2006 07:59 PM
convert stadium truck to street truck salazar44 Electric On-Road 2 06-26-2004 07:26 PM
Matt Francis Truck & Extra Truck Parts olewarrior R/C Items: For Sale/Trade 4 12-02-2002 06:13 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
