Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-04-2008, 05:35 PM   #16
Suspended
r u guys using the x/6 chassis
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 09-04-2008, 05:39 PM   #17
SpeedyDad's Avatar
The X-60 uses a longer chassis than the X-6
X Factory X-60 - Keep on Truckin'
X Factory - www.xfactoryrc.com
BC1 Graphics
SpeedyDad is offline   Reply With Quote
Old 09-04-2008, 05:47 PM   #18
Suspended
when will i be able to buy one
www.michianarc.com
Old 09-04-2008, 05:51 PM   #19
Chris__RC's Avatar
Originally Posted by SpeedyDad View Post
The X-60 will be T4 based.
What you saw on Brian's truck was just Brian trying things. He does that. You can fit anything with time and a Dremel.
Don't forget, what you see until the actual kit is in the box are just working prototypes. At times, you may see odd things on them. We try things to see what they will do. My X-60 has a rather interesting shock setup on it. It will never make production but it was fun seeing what it would do.
What shock setup is it?
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 09-04-2008, 06:07 PM   #20
crazyjr's Avatar
I'm running them on my X-60 currently
The QC question was going to be my first one thanks. Question 2, If converted, will you be able to go back to stock? Here in Ga. we got varying track conditions, and it might be better to go back to stock. I could get a second T4 to leave stock if i needed.
crazyjr is offline   Reply With Quote
Old 09-04-2008, 08:16 PM   #21
SpeedyDad's Avatar
Hopefully, mid to late October if all testing goes well.
Truck front shocks on all corners, a special short rear shock tower, and a leaned in custom front shock tower, all to run a low profile body. It worked fine, but wasn't 100% optimal. I'm back to the standard AE truck shocks for testing of final components.
Nothing of the T4 is modified or cut in any way. You could put it back to a T4 if you wanted (or build a 2nd X-60 for other tracks). We have found that the X-60 can go from varied track conditions with little change to setup.
BC1 Graphics
Old 09-04-2008, 08:27 PM   #22
STEALTH's Avatar
How about some clear and detailed pics since the kit has already raced at some major events... it certainly can't hurt especially if you mention any needed disclaimers....
STEALTH is offline   Reply With Quote
Old 09-04-2008, 09:09 PM   #23
SpeedyDad's Avatar
The true kit has not raced at any races yet. All the trucks that have been raced are hand-built prototypes built by myself and Brian Kinwald. The only pre-production actual molded parts completed so far are the rear arms.
We'll get more pics out when we get closer. The production chassis will be a little different than the pics that have been posted so far. Be patient. Work is being done as fast as can be.
BC1 Graphics
Old 09-04-2008, 09:24 PM   #24
Paul_Sinclair's Avatar
Send a message via AIM to Paul_Sinclair
Chazz took quite a few detail pics at the Nat's of our trucks, hopefully those can be posted when we get our galleries up.
Crazyjr - yes, as SpeedyDad said you'll be able to convert back without a problem, though given it is a chassis change it wouldn't be something I'd want to try at a track. What kind of conditions are you worried about? I've been running my X - 60 at a blown-out gas track here in Nashville with really good results.
X Factory - Novak Electronics - SMC Batteries - Vinyl Graphics Unlimited - Kolors By Kropy - Lunsford - MIP - B Fast Performance Diff Parts
Paul_Sinclair is offline   Reply With Quote
Old 09-04-2008, 10:04 PM   #25
crazyjr's Avatar
What i was refering to was if i know the track i'm going to is nasty bad and i don't have a good setup, I can revert back to my known setup as a T4. I wouldn't want to rebuild the truck at the track myself. Just saying till i know the X-60 could handle it, I wanted it where i could revert back. As said, I could buy a spare and keep it till i get a good setup if necessary
Old 09-05-2008, 08:11 AM   #26
scrubnick's Avatar
Send a message via AIM to scrubnick
Michigan has a ton of loose dirt, blown out tracks and the X-60 has been doing really well on them. I'm running the shocks of my GT with the same pistons/oil/springs and I haven't seen a reason to make a change yet. The 4-gear trans and the mid-motor positioning makes for a heck of a truck.
I think the avatar says it all...
Team Tekin, Team CBA
scrubnick is offline   Reply With Quote
Old 09-06-2008, 12:20 AM   #27
STEALTH's Avatar
Paul - I'm sure I'm not the only one looking forward to it! Glad to see X-Factory covering all 3 major Off-Road Classes now! I still remember the early days with just the X-5...
Old 09-07-2008, 08:55 PM   #28
Default X-60
I have driven Speedy Dads X-60 here locally and i like the way it feels over my T4, My home track is SRS the home of the Cactus Classic, Even the first version that i drove. It seem to handle better than a T4, but it also depends on your diving style, It seem to be able to dive into the corners better. Dont get me wrong i love my T4FT but this could give the X-Factory line the push it needs to put more kits on the Podium.
P.S. Good work on the X-60 Speedy Dad. See you and Penquin Back at SRS after States.
Az-Cowboy is offline   Reply With Quote
Old 09-07-2008, 10:41 PM   #29
SpeedyDad's Avatar
Thanks Cowboy. See you after States.
BC1 Graphics
Old 09-10-2008, 04:56 PM   #30
gone banana's Avatar
all i know i built 2 from the x-6 kit 4 chassis for indoor offroad carpet racing it rock
tq with them.
when they come out i`m going to get two of them
i will be going to the crcrc race in jan. can`t wait to meet you
speed dad what the height of the rear shock tower
i have been using b4 rear shock on my
rick seffrood
gone banana is offline   Reply With Quote
Forum Jump
Heng Long Mad Truck (China) 1/10 EP Monster Truck??!! ALCW Malaysian R/C Racers 17 10-01-2009 03:53 AM
RPM 'Clawz' Stadium Truck Wheels & Truck Tires mrbrnz Australia For Sale/Trade 0 10-30-2007 01:25 AM
NIP Novak GTX/Spintec/Integy Tire Truer w/3-16" truck arbor/NIP TRC Truck Foams ridgewaybodies R/C Items: For Sale/Trade 24 04-29-2006 07:59 PM
convert stadium truck to street truck salazar44 Electric On-Road 2 06-26-2004 07:26 PM
Matt Francis Truck & Extra Truck Parts olewarrior R/C Items: For Sale/Trade 4 12-02-2002 06:13 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
