4wd Buggy Front Tire Options? >
Old 06-10-2008, 09:36 PM
Nitronut3's Avatar
Default 4wd Buggy Front Tire Options?
Hello,
Im looking for a good tire to run on a outdoor track with low bite and a little fluff on top.
Im going to run a bowtie rear, and will maby custom make a Bowtie front.
I have a set of JC double Dee's in green compound,
What tires would you guys run.
Anyhelp im running a xxx-4 G+
Thanks,
Nate
Nitronut3 is offline
Old 06-10-2008, 09:53 PM
rdub202's Avatar
Trader Rating: 19 (100%+)
how bout some goosebumps
or ifmar studs (red)
all around
rdub202 is offline
Old 06-10-2008, 09:54 PM
Trader Rating: 23 (100%+)
this might help
http://www.losi.com/Tires/
not home is offline
Old 06-11-2008, 12:15 AM
ngo8's Avatar
i just ordered a set of double dees hopeing they work but currently using ifmar studs they work good but a little to much front bite .
ngo8 is offline
Old 06-11-2008, 08:04 AM
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
This all depends on what your track is like, i personally run holeshots and they hook up great.
Bulldawg RC is offline
Old 06-11-2008, 08:45 AM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
prolly a real loose track. Step pins would work and also IFMARS too.
BuggyKing is offline
Old 06-11-2008, 09:16 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
What compound are you running for IFMAR Studs for the front and the rear tires?
If its red compound all around, you could try going with silver fronts for the ifmar studs. This could calm down the front bite a bit.
As for tires, I wish losi didn't stop making the ifmar pins for 4wd fronts. I really liked that tire. Great when you want something between a stud and holeshots.
Another tire combo that worked on multi-surface conditions that I liked was proline m3 steppins all around.
Cain is online now
Old 06-11-2008, 09:28 AM
KThatcher's Avatar
Trader Rating: 64 (100%+)
Goosebumpers work great... also you can never go wrong with double dees or holeshots..
KThatcher is offline
Old 06-16-2008, 02:36 PM
Jason Ruona's Avatar
JConcepts Goosebumps are probably the tire for you. I would run them all the way around.
Jason Ruona is offline
Old 06-17-2008, 10:24 AM
Trader Rating: 42 (100%+)
Jason, the same Goosebump tire fits both 4WD front and rear?
ridgewaybodies is offline
Old 06-17-2008, 01:27 PM
rdub202's Avatar
no
4wd front goosebump
2wd/4wd rear goosebump
rdub202 is offline
Old 06-18-2008, 03:33 AM
The JC website is very confusing on the Goose Bumps tire description then.
Goose Bumps – Green Compound (fits 2.2” 4wd front wheel)
Part # - 3019-02
How do you order 4WD front and 2/4WD rear if there is no option to choose front or rear?
Old 06-18-2008, 03:37 AM
The way I understand it is there is one Goose Bumps tire and it fits 4WD front and 2/4WD rear.
Jason or Andrew, can you please confirm?
Old 06-18-2008, 04:24 AM
Trader Rating: 24 (100%+)
It's true. I ordered a full set of 4wd goosebumps from the jConcepts site.
BobWoodhouse is offline
Old 06-18-2008, 05:13 AM
jobo_ph's Avatar
+1 (billion)!
jobo_ph is offline
