HELP!!! How to Change the rear bearing in my novak brushless motor
I can not find any place that shows or tells you how to change the bearing in the rear of my novak Volociti 5.5R brushless motor. Please help!!!!
thread-necro
I have the plastic bit with the bearing in it having removed the three screws but the bearing seems pretty tightly glued/pressed in the hole for it. Obviously I can't push it out from the other side. No idea how to remove it, don't want to scratch the inside of the bearing as it is new and I am just replacing with ceramic for kicks, would be good to keep it as a spare.
There is only about 1mm sticking out very hard to get a grip on. Novak sell replacement bearings so there must be a way to do this. Any tips folks?
thanks
edit: its a novak ballistic
edit2: got it out. I tried acetone but didn't seem to make any difference (might have though). In the end I removed the rubber part and sunk the bearing cap and bearing in boiled water for a few minutes. Took it out and it came out with a bit of effort and leverage. So that's one way!
thanks
info from novak tech support
Hello,
The bearings are glued and pressed in using heat. You would have to bake the endbell in an oven on low temps to get the bearing out and back in! Be sure to wear proper safety protection such as gloves and safety glasses and proper tools that are rated for working with high temps when doing this. You have to use a high temp bearing glue when replacing the new bearing. If you are not an adult make sure you have adult to help you out.
Newman
Customer Service
Technical Support
Novak Electronics, Inc.
Newman
Customer Service
Technical Support
