Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-03-2008, 03:10 PM   #31
Send a message via Yahoo to viperbill1963
Thumbs up better cooling
Originally Posted by Murphster View Post
Finished product.
Some changes to hopefully avoid thermaling issues. Don't know if it will help or not.
May cut the front window between the Novak and Racing and install more of the mesh that's covering the fan there.
I'm trying some of the concepts I have learned over the years Air-cooling PCs and videocards for overclocking.
This Home Theater PC has been overclocked by a full Ghz for two years now, inside a cabinet with purely air cooling.
[IMG][/IMG]
i would cut out the front area on the windshied and replace it with some screen material to allow more air inside the body i used some scrap balsa wood to make a frame to hold the screen to the body with some silicone sealant works great!!
hyper 9 ,os speed,.21 os2060 pipe jr servo 9100s 9100t
diggity designs d12 conversion hitec servo smc lipo 4000mah tekin 13.5 setup
viperbill1963 is offline   Reply With Quote
Old 06-03-2008, 09:50 PM   #32
did novak go with a two battery or one battery setup
xxxtruck is offline   Reply With Quote
Old 06-04-2008, 08:38 AM   #33
For suggested buggy installations, click on the photos in the listings. Some require both battery boxes; others, only one:
Ten Novak Conversion Kits Available
All of the kits include two battery boxes, straps and hardware.
NovakTwo is offline   Reply With Quote
Old 06-04-2008, 12:30 PM   #34
Exclamation lutach
Originally Posted by lutach View Post
I haven't had a problem yet with my Hard RC-Monster pinion gears on RR 48T steel spur gear. The only thing that happens, is they just get a bit shiny where the contact is made. Sorry for all the pictures.
hey lutach which conversion is on your buggy i like motor mount on your
Old 06-04-2008, 02:26 PM   #35
Pretty sure Lutach makes his own.
Question for NovakTwo.
I realize that you want to sell product, but will the new engine heatsink cool the motor(HV Maxx 6.5) appreciably more than the big one that came with my motor?
The companies moving into the Electric 1/8th scale space have been pretty close to the vest about delays, and quality control, so try to back it up with real test results, because if I buy it, I will test it, and be merciless in the boards if it looks like you've released something that obviously hasn't been tested well and/or is a waste of time and money. The guys that are so forgiving of Castle in releasing an ESC that obviously wasn't ready for primetime must have more disposible income and time than I do.
Any reason the Losi kit is taking longer? Not that it matters to me personally, as I ended up building my own after waiting for months for Novak to ship theirs.
Losi 8ight - Novak HVMAXX 6.5
X-Ray 808/V-Spec
Jammin CRT/Jammin.28
Slash/like it came out da box.
Murphster is offline   Reply With Quote
Old 06-04-2008, 07:04 PM   #36
lutach's Avatar
I bought that one. I will be making a ARTR kit soon. I'm just waiting for the place that will be doing the chassis to get back to me.
lutach is offline   Reply With Quote
Old 06-05-2008, 09:24 PM   #37
they have been testing for a while. I have the pro hv and 6.5 hv in revo and have ran 30 min no problem.
Old 06-06-2008, 08:55 AM   #38
The Evicerator
Well I'm not NovakTwo, but I feel I can answer some of your questions
As far as the new heatsink arrangement: We feel that it does a better job of cooling the motor down than simply the original heatsink for a number of reasons:
1.) It has a fan mounted to it... airflow over a heatsink dramatically helps dissapate heat.
2.) The heatsink is connected to the motor plate...which is connected to the chassis...effectively sinking heat away from the motor into the chassis and using the chassis as usable heatsinking area.
When heatsinks are concerned, generally more surface area = more cooling.
As far as delay in releasing the Losi conversion kits, I think it has had something to do with waiting on batches of the motor plates to be completed.
Steve Weiss -Steve@teamnovak.com
<TEAM NOVAK><XRAY><RCAMERICA><HUDY><JACO><SMC><AIRTRONIC S><JAF RACING><POUND IT PAINTS><RPG Designs><TEAM KINWALD><TEAM STEVE>
I do my RC shopping at www.nexusracing.net!
Steve Weiss is offline   Reply With Quote
Old 06-06-2008, 09:40 AM   #39
Thanks Steve for the response, you guys are usually on top of things as always. Having been a Novak customer for more than 25 years I can say that Bob and his company value their reputation very much and have always develped and marketed products that were in keeping with their high standards. I have no doubt that they have tested this product very throughly and its ready for "primetime". I may end up eating those words but I doubt it very much. My HV 6.5 system has been in two trucks so far and now its in my Ofna Ravager which I got the conversion kit for last night. It took me about 3 hrs. with beer breaks to install and I tested it on the road with foams in the dark to see if it was OK. It ran fine as I could tell from a short run, today after work I will put some knobbies on it and run it on the dirt track & see how it goes. So far so good, spur-pinion combo is a little loud but with the nitro motor in it I probably couldn't hear it before. Now its so quiet you can hear everything meshing. I'll get some photos and more run time on it and report back how it runs. Thanks Novak, keep it Orange!
monsterbft is offline   Reply With Quote
Old 06-06-2008, 11:37 AM   #40
Default heat transfer paste
folks:
I see where the heat transfer paste is used from the motor to the heat sink. Would it be of advantage applied between the heat sink and mounting plate and from the mounting plate to the aluminum chassis? Is this paste similar to computer chip heat transfer paste? Thanks
MartinB is offline   Reply With Quote
Old 06-06-2008, 08:25 PM   #41
I have ran the novak 6.5 in my gorillamaxx race e-maxx for two years now and it has been good to me. I just got the jammin buggy done and it's been a nightmare. After a 5 minute heat, the esc and motor where 160 and the batts where warm also.(85 outside) and that's with 2 7.4 8000mah batts. It is pretty fast but overheats and drains the batts why to fast compared to the e-maxx. call novak and they have no suggestions.??? it has to be geared to high for there motors. I think i'm going to sell it.
bring it on is offline   Reply With Quote
Old 06-06-2008, 08:56 PM   #42
happywing's Avatar
I ran the 6.5 in a buggy and it worked out OK. The fans have to be working and the gearing has to be spot-on. I ran an MBX5 with 12/46 and it got hot. With 10/46 it was very cool, but slow. 11/46 was the ticket. There are no gearing choices. You have to find what works and stick with it.
E-MBX-6T mmmV3/Neu 1515 1.5d/f
RC10-T4 RS/17.5 Redline
Livin' Large at the Barn!!!
Go To www.rcproductdesigns.com For Awesome Stuff!
happywing is offline   Reply With Quote
Old 06-06-2008, 09:56 PM   #43
Trader Rating: 40 (100%+)
If you are running two separate LiPo packs with separate connectors with the Novak HV-Maxx speed control you should be aware that they get drained at different rates. My conjecture is that the BEC only runs off of only one of the 7.2V inputs. That means you should figure out which one is being drained more and run a 2-cell smart stop on that one pack. For example, I ran my 6.5 with two separate SMC 5000 packs for a 10 minute run (to see what my current consumption was to plan for racing). I fiound one pack took 3094 mAHr and the other took 3294 mAHr. So if you used a 4-cell smart stop, one of the packs would be over-discharged by the time the cut-off stops the car.
This is a repeatable situation, not an isolated occurrance (at least with my ESC). The pack connected to one specific connector always gets drained more, The difference depends on on how long the car was run.
ta_man is offline   Reply With Quote
Old 06-06-2008, 10:53 PM   #44
ya, I'm very awair of that. that's novak for you.
In my buggy i have the gear novak recomends for the jammin(11) that's the smallest they make.
Old 06-09-2008, 09:14 AM   #45
Is this situation of unequal draining true with the new HV Pro? Does anyone know? Thanks for input.
nutz4rcyktw is offline   Reply With Quote
Forum Jump
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 18865 11-18-2009 04:00 PM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
**OFFICIAL ROCK CRAWL'N THREAD** Elec, Nitro & Any Scale! CLUBCONCEPTS Monster Trucks 4 03-06-2007 05:23 AM
For sale 2 RC10 DS cars, 1 nitro, 1 electric both team kits Ron R/C Items: For Sale/Trade 0 10-24-2001 08:18 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
