new pack of gp3300's
just picked up a new pack of gp3300's and had a couple of questions
what do you normaly charge at? with my sanyo 3000hv's i charge at 6amps with a cut off of 4mvs per cell. to get the most of these gp's would i charge the same? what about cell shrink wrap? and what battery bars do you use? on my 3000's i used the deans and they are a snug fit. |
Re: new pack of gp3300's
Originally posted by xxxtracer32 just picked up a new pack of gp3300's and had a couple of questions what do you normaly charge at? with my sanyo 3000hv's i charge at 6amps with a cut off of 4mvs per cell. to get the most of these gp's would i charge the same? what about cell shrink wrap? and what battery bars do you use? on my 3000's i used the deans and they are a snug fit. Cell shrink wrap is completely optional (assuming the cells still have their factory shrinkwrap underneath the label). It does help protect the label from wearing off, but some people also feel that it traps more heat. I've had good luck w/ using the Deans 2.0 bars. |
I am charging my GP3300's at 6.5 amps, and peaking them at 7 for stock racing. Provides plenty of punch, and runtime is not an issue, usually get around 9-10 mins.
thanks for the reply.
ive been useing the deans bars and they are a tight fit in my xxxt chassie. are all the bars the same? |
Originally posted by xxxtracer32 thanks for the reply. ive been useing the deans bars and they are a tight fit in my xxxt chassie. are all the bars the same? The Deans 2.0 works well w/ the GP3300's, but the 3.0 works better w/ the Sanyo 3000s. They are a very tight fit in the XXXT, but if you're still having problems, you can always file down the battery holder a little bit. |
Originally posted by xxxtracer32 just picked up a new pack of gp3300's and had a couple of questions what do you normaly charge at? with my sanyo 3000hv's i charge at 6amps with a cut off of 4mvs per cell. to get the most of these gp's would i charge the same? what about cell shrink wrap? and what battery bars do you use? on my 3000's i used the deans and they are a snug fit. |
for the bars i went to my lhs and looked at all the diffrent bars, now i know what your talking about. my friend that i race with used orion bars with his so ill be trying those.
thanks for the info, any more suggestions would be great. |
